Providing Context-Aware Adaptations Based on a Semantic Model - Archive ouverte HAL Access content directly
Conference Papers Year : 2011
(1) , (2) , (1)
1
2
René Meier
  • Function : Author
  • PersonId : 1015836
Smartphones and tablet PCs are on the verge of revolutionizing the information society by offering high quality applications and almost permanent connectivity to the Internet in a mobile world. They naturally support new applications that take advantage of context information like location, time and other environmental conditions. However, developing these novel context-aware applications is challenging as it is difficult to a priori anticipate their execution context and the adaptations that might be necessary to use new context information. This issue is reinforced by the semantic gap between the low-level technical realization of adaptation mechanisms and the demand to describe adaptations in abstract and comprehensible business terms.This paper presents programming support for context-aware adaptations based on a semantic model that builds on the AOCI framework. Using such a model, applications and adaptations can be described by means of easy to comprehend business terms. Thereby the model enables the AOCI framework to store and publish both context and domain-specific run-time information and provides a basis for high-level and tailored programming support. This enables to transparently select adaptations based on various criteria and integrate them into applications at run-time. At the level of adaptation mechanisms our approach supports integration for permanent changes using Aspect-Oriented Programming and more importantly for spontaneous and short-time integration of web services by means of interceptors.
978-3-642-21387-8_5_Chapter.pdf (346.84 Ko) Télécharger le fichier
Dates and versions
hal-01583585 , version 1 (07-09-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Rüdiger Kapitza, René Meier, Guido Söldner. Providing Context-Aware Adaptations Based on a Semantic Model. 11th Distributed Applications and Interoperable Systems (DAIS), Jun 2011, Reykjavik, Iceland. pp.57-70, ⟨10.1007/978-3-642-21387-8_5⟩. ⟨hal-01583585⟩
45 View
93 Download
Share
