Instability of FIFO in the permanent sessions model at arbitrarily small network loads, Proc. of SODA'07, 2007. ,
DOI : 10.1145/1541885.1541894
Synchronization and linearity, 1992. ,
Estimating the Worst-case Delay in FIFO Tandems Using Network Calculus, Proceedings of the 3rd International Conference on Performance Evaluation Methodologies and Tools, 2008. ,
DOI : 10.4108/ICST.VALUETOOLS2008.4388
Adversarial queuing theory, Journal of the ACM, vol.48, issue.1, pp.13-38, 2001. ,
DOI : 10.1145/363647.363659
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.24.4618
Optimal routing for end-to-end guarantees using network calculus. Performance Evaluation, pp.11-12883, 2008. ,
DOI : 10.1016/j.peva.2008.04.008
URL : https://hal.archives-ouvertes.fr/inria-00214235
Tight performance bounds in the worst-case analysis of feed-forward networks, Proceedings of Info- com'2010, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00408717
An algorithmic toolbox for network calculus. Discrete Event Dynamic Systems, pp.3-49, 2008. ,
DOI : 10.1007/s10626-007-0028-x
URL : https://hal.archives-ouvertes.fr/inria-00123643
Worst-case delay bounds with fixed priorities using network calculus, Proceedings of Valuetools'11, 2011. ,
Tightening end to end delay upper bound for AFDX network calculus with rate latency FCFS servers using network calculus, Proc. of WFCS, 2008. ,
Performance evaluation of network processor architectures: combining simulation with analytical estimation, Computer Networks, vol.41, issue.5, pp.641-665, 2003. ,
DOI : 10.1016/S1389-1286(02)00454-1
A filtering theory for deterministic traffic regulation, Proceedings of INFOCOM '97, pp.436-443, 1997. ,
DOI : 10.1109/INFCOM.1997.644492
Performance Guarantees in Communication Networks, TNCS, 2000. ,
DOI : 10.1007/978-1-4471-0459-9
A calculus for network delay. I. Network elements in isolation, IEEE Transactions on Information Theory, vol.37, issue.1, pp.114-131, 1991. ,
DOI : 10.1109/18.61109
A calculus for network delay. II. Network analysis, IEEE Transactions on Information Theory, vol.37, issue.1, pp.132-141, 1991. ,
DOI : 10.1109/18.61110
WLC15-2: A Network Calculus Approach to Probabilistic Quality of Service Analysis of Fading Channels, IEEE Globecom 2006, 2006. ,
DOI : 10.1109/GLOCOM.2006.699
Theories and models for Internet quality of service, Proc. of the IEEE, pp.1565-1591, 2002. ,
DOI : 10.1109/JPROC.2002.802002
Timed automata based analysis of embedded system architectures, Proceedings 20th IEEE International Parallel & Distributed Processing Symposium, 2006. ,
DOI : 10.1109/IPDPS.2006.1639422
Stochastic Network Calculus, 2008. ,
Network Calculus: A Theory of Deterministic Queuing Systems for the Internet, volume LNCS 2050, 2001. ,
A methodology for computing end-toend delay bounds in FIFO-multiplexing tandems. Performance Evaluation, pp.11-12922, 2008. ,
End-to-end response time with fixed priority scheduling: trajectory approach versus holistic approach, International Journal of Communication Systems, vol.42, issue.1, pp.37-56, 2005. ,
DOI : 10.1002/dac.688
Influence of different system abstractions on the performance analysis of distributed real-time systems, Proceedings of the 7th ACM & IEEE international conference on Embedded software , EMSOFT '07, 2007. ,
DOI : 10.1145/1289927.1289959
Generating Linear Extensions Fast, SIAM Journal on Computing, vol.23, issue.2, pp.373-386, 1994. ,
DOI : 10.1137/S0097539791202647
URL : http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.52.3057&rep=rep1&type=pdf
Stability and Delay Bounds in Heterogeneous Networks of Aggregate Schedulers, IEEE INFOCOM 2008, The 27th Conference on Computer Communications, 2008. ,
DOI : 10.1109/INFOCOM.2008.208
pay bursts only once " does not hold for non-FIFO guaranteed rate nodes. Performance Evaluation, pp.1-4366, 2005. ,
DOI : 10.1016/j.peva.2005.07.004
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.87.8264
The DISCO network calculator, Proceedings of the 1st international conference on Performance evaluation methodolgies and tools , valuetools '06, 2006. ,
DOI : 10.1145/1190095.1190105
Delay bounds under arbitrary multiplexing, 2007. ,
DOI : 10.1109/infocom.2007.228
Delay Bounds under Arbitrary Multiplexing: When Network Calculus Leaves You in the Lurch..., IEEE INFOCOM 2008, The 27th Conference on Computer Communications, 2008. ,
DOI : 10.1109/INFOCOM.2008.228
Timeliness of Real-Time IP Communication in Switched Industrial Ethernet Networks, IEEE Transactions on Industrial Informatics, vol.2, issue.1, pp.25-39, 2006. ,
DOI : 10.1109/TII.2006.869934
Any work-conserving policy stabilizes the ring with spatial re-use, IEEE/ACM Transactions on Networking, vol.4, issue.2, pp.205-208, 1996. ,
DOI : 10.1109/90.490748
Embedded Software in Network Processors ??? Models and Algorithms, Proc. of EMSOFT, 2001. ,
DOI : 10.1007/3-540-45449-7_29
Real-time calculus for scheduling hard real-time systems, 2000 IEEE International Symposium on Circuits and Systems. Emerging Technologies for the 21st Century. Proceedings (IEEE Cat No.00CH36353), 2000. ,
DOI : 10.1109/ISCAS.2000.858698
Holistic schedulability analysis for distributed hard real-time systems, Microprocessing and Microprogramming, vol.40, issue.2-3, pp.117-134, 1994. ,
DOI : 10.1016/0165-6074(94)90080-9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.30.2371
Linear Programming, Foundations and extensions, 2000. ,
DOI : 10.1057/palgrave.jors.2600987
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.111.1824
