Fuzzy Redundancy Adaptation and Joint Source - Network Coding for VANET Video Streaming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Video communication VANETs has many applications, such as emergency video transmission or inter-vehicle entertainment. However, delivering video to high mobile vehicles faces challenges such as packet loss due to intermittent connectivity and channel variations. Thus, designing a reliable approach for video streaming over such harsh scenarios is needed. Hence, we propose a reliable approach based on random practical network coding and source coding. This approach integrates the benefits of network coding with Multiple Description Coding to achieve robust streaming over VANET. Furthermore, we propose a redundancy controller based on fuzzy inference system to adjust the amount of redundant packets based on vehicular traffic density and SNR of the channel. Simulation shows the proposed approach achieves better protection against packet loss, application layer throughput and video quality.
978-3-642-21560-5_38_Chapter.pdf (817.13 Ko) Télécharger le fichier
hal-01583634 , version 1 (07-09-2017)
Paternité
Alberto J. Gonzalez, Kayhan Zrar Ghafoor, Ramon Piney, Andre Rios, Jesus Alcober, et al.. Fuzzy Redundancy Adaptation and Joint Source - Network Coding for VANET Video Streaming. 9th Wired/Wireless Internet Communications (WWIC), Jun 2011, Vilanova i la Geltrú, Spain. pp.458-469, ⟨10.1007/978-3-642-21560-5_38⟩. ⟨hal-01583634⟩
145 Consultations
119 Téléchargements
