Theories and models for Internet quality of service, Proc. of the IEEE, pp.1565-1591, 2002. ,
DOI : 10.1109/JPROC.2002.802002
Performance evaluation of network processor architectures: combining simulation with analytical estimation, Computer Networks, vol.41, issue.5, pp.641-665, 2003. ,
DOI : 10.1016/S1389-1286(02)00454-1
Timeliness of Real-Time IP Communication in Switched Industrial Ethernet Networks, IEEE Transactions on Industrial Informatics, vol.2, issue.1, pp.25-39, 2006. ,
DOI : 10.1109/TII.2006.869934
Tightening end to end delay upper bound for afdx network calculus with rate latency fcfs servers using network calculus, Proc. of WFCS, 2008. ,
Performance Guarantees in Communication Networks, TNCS, 2000. ,
DOI : 10.1007/978-1-4471-0459-9
Network Calculus: A Theory of Deterministic Queuing Systems for the Internet, 2001. ,
Holistic schedulability analysis for distributed hard real-time systems, Microprocessing and Microprogramming, vol.40, issue.2-3, pp.117-134, 1994. ,
DOI : 10.1016/0165-6074(94)90080-9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.30.2371
End-to-end response time with fixed priority scheduling: trajectory approach versus holistic approach, International Journal of Communication Systems, vol.42, issue.1, pp.37-56, 2005. ,
DOI : 10.1002/dac.688
Timed automata based analysis of embedded system architectures, Proceedings 20th IEEE International Parallel & Distributed Processing Symposium, 2006. ,
DOI : 10.1109/IPDPS.2006.1639422
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.507.4616
Influence of different system abstractions on the performance analysis of distributed real-time systems, Proceedings of the 7th ACM & IEEE international conference on Embedded software , EMSOFT '07, 2007. ,
DOI : 10.1145/1289927.1289959
A filtering theory for deterministic traffic regulation, Proceedings of INFOCOM '97, pp.436-443, 1997. ,
DOI : 10.1109/INFCOM.1997.644492
A calculus for network delay. I. Network elements in isolation, IEEE Transactions on Information Theory, vol.37, issue.1, pp.114-131, 1991. ,
DOI : 10.1109/18.61109
Synchronization and linearity, 1992. ,
Adversarial queuing theory, Journal of the ACM, vol.48, issue.1, pp.13-38, 2001. ,
DOI : 10.1145/363647.363659
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.24.4618
Any work-conserving policy stabilizes the ring with spatial re-use, IEEE/ACM Transactions on Networking, vol.4, issue.2, pp.205-208, 1996. ,
DOI : 10.1109/90.490748
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.58.8204
Instability of FIFO in the permanent sessions model at arbitrarily small network loads, Proc. of SODA'07, 2007. ,
DOI : 10.1145/1541885.1541894
Stability and Delay Bounds in Heterogeneous Networks of Aggregate Schedulers, IEEE INFOCOM 2008, The 27th Conference on Computer Communications, 2008. ,
DOI : 10.1109/INFOCOM.2008.208
Estimating the worstcase delay in fifo tandems using network calculus, Proc. of Value- tools, 2008. ,
???Pay bursts only once??? does not hold for non-FIFO guaranteed rate nodes, Performance Evaluation, vol.62, issue.1-4, pp.366-381, 2005. ,
DOI : 10.1016/j.peva.2005.07.004
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.87.8264
The DISCO network calculator, Proceedings of the 1st international conference on Performance evaluation methodolgies and tools , valuetools '06, 2006. ,
DOI : 10.1145/1190095.1190105
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.143.2952
Optimal routing for end-to-end guarantees using Network Calculus, Performance Evaluation, vol.65, issue.11-12, pp.11-12, 2008. ,
DOI : 10.1016/j.peva.2008.04.008
URL : https://hal.archives-ouvertes.fr/inria-00214235
Delay Bounds under Arbitrary Multiplexing: When Network Calculus Leaves You in the Lurch..., IEEE INFOCOM 2008, The 27th Conference on Computer Communications, 2008. ,
DOI : 10.1109/INFOCOM.2008.228
Embedded Software in Network Processors ??? Models and Algorithms, Proc. of EMSOFT, 2001. ,
DOI : 10.1007/3-540-45449-7_29
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.28.6412
Sensor Network Calculus ??? A Framework for Worst Case Analysis, Proc. of 1st International Conference on Distributed Computing in Sensor Systems, 2005. ,
DOI : 10.1007/11502593_13
WLC15-2: A Network Calculus Approach to Probabilistic Quality of Service Analysis of Fading Channels, IEEE Globecom 2006, 2006. ,
DOI : 10.1109/GLOCOM.2006.699
Tight performance bounds in the worst-case analysis of feed-forward networks, INRIA, Tech. Rep, vol.7012, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00408717
Generating Linear Extensions Fast, SIAM Journal on Computing, vol.23, issue.2, pp.373-386, 1994. ,
DOI : 10.1137/S0097539791202647
URL : http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.52.3057&rep=rep1&type=pdf
A methodology for computing end-to-end delay bounds in FIFO-multiplexing tandems, Performance Evaluation, vol.65, issue.11-12, pp.11-12, 2008. ,
DOI : 10.1016/j.peva.2008.04.002
Real-time calculus for scheduling hard real-time systems, 2000 IEEE International Symposium on Circuits and Systems. Emerging Technologies for the 21st Century. Proceedings (IEEE Cat No.00CH36353), 2000. ,
DOI : 10.1109/ISCAS.2000.858698
An Algorithmic Toolbox for Network Calculus, Discrete Event Dynamic Systems, pp.3-49, 2008. ,
DOI : 10.1007/s10626-007-0028-x
URL : https://hal.archives-ouvertes.fr/inria-00123643
