Abstract Categorial Grammars as a Model of the Syntax-Semantics Interface for TAG
We present the ACG formalism and how to use it as a model of the syntax-semantics interface of Tree Adjoining Grammars.
tag+13-tutorial.handout.pdf (381.11 Ko)
Télécharger le fichier
examples.zip (13.17 Ko)
