An a posteriori error estimator based on shifts for positive hermitian eigenvalue problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
This work deals with an a posteriori error estimator for hermitian positive eigenvalue problems. The proposed estimator is based on the residual and the definition of suitable shifts in the matrix spectrum. The mathematical properties (certification and sharpness) are investigated and some numerical experiments are proposed.
ArtAPosterioriErr-3.pdf (430.97 Ko) Télécharger le fichier
hal-01584180 , version 1 (08-09-2017)
  • HAL Id : hal-01584180 , version 1
Athmane Bakhta, Damiano Lombardi. An a posteriori error estimator based on shifts for positive hermitian eigenvalue problems. 2017. ⟨hal-01584180⟩
408 Consultations
228 Téléchargements
