Characterizations of Solutions in Geochemistry: Existence, Uniqueness and Precipitation Diagram - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Geosciences Année : 2019
In this paper, we study the properties of a geochemical model involving aqueous and precipitation-dissolution reactions at a local equilibrium in a diluted solution. This model can be derived from the minimization of the free Gibbs energy subject to linear constraints. By using logarithmic variables, we define another minimization problem subject to different linear constraints with reduced size. The new objective function is strictly convex, so that uniqueness is straightforward. Moreover, existence conditions are directly related to the totals, which are the parameters in the mass balance equation. These results allow us to define a partition of the totals into mineral states, where a given subset of minerals are present. This precipitation diagram is inspired from thermodynamic diagrams where a phase depends on physical parameters. Using the polynomial structure of the problem, we provide characterizations and an algorithm to compute the precipitation diagram. Numerical computations on some examples illustrate this approach.
main.pdf (411.83 Ko) Télécharger le fichier
hal-01584490 , version 1 (08-09-2017)
hal-01584490 , version 2 (04-12-2018)
Jocelyne Erhel, Tangi Migot. Characterizations of Solutions in Geochemistry: Existence, Uniqueness and Precipitation Diagram. Computational Geosciences, 2019, 23 (3), pp.523-535. ⟨10.1007/s10596-018-9800-2⟩. ⟨hal-01584490v2⟩
431 Consultations
454 Téléchargements
