Dominant point detection based on discrete curve structure and applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computer and System Sciences Année : 2018
In this paper, we investigate the problem of dominant point detection on digital curves which consists in nding points with local maximum curvature. Thanks to previous studies of the decomposition of curves into sequence of discrete structures [1, 2, 3], namely maximal blurred segments of width ν [4], an initial algorithm has been proposed in [5] to detect dominant points. However, an heuristic strategy is used to identify the dominant points. We now propose a modied algorithm without heuristics but a simple measure of angle. In addition, two applications are as well presented: (1) polygonal simplication to reduce the number of detected dominant points by associating a weight to each of them, and (2) classication using the polygon issued from the reduced dominant points. The experimental results demonstrate the eciency and robustness of the proposed method.
mainJournal.pdf (1.28 Mo) Télécharger le fichier
hal-01584733 , version 1 (09-09-2017)
Hayat Nasser, Phuc Ngo, Isabelle Debled-Rennesson. Dominant point detection based on discrete curve structure and applications. Journal of Computer and System Sciences, 2018, 95, pp.177-192. ⟨10.1016/j.jcss.2017.07.007⟩. ⟨hal-01584733⟩
230 Consultations
789 Téléchargements
