Rouyer-Degli, Optimal blurred segments decomposition of noisy shapes in linear time, Computers & Graphics, vol.30, issue.3036, 2006. ,
Tangential cover for thick digital curves, Pattern Recognition, vol.42, issue.10, p.22792287, 2009. ,
DOI : 10.1007/978-3-540-79126-3_32
URL : https://hal.archives-ouvertes.fr/hal-00622470
Optimal Time Computation of the Tangent of a Discrete Curve: Application to the Curvature, LNCS, vol.1568, p.3140, 1999. ,
DOI : 10.1007/3-540-49126-0_3
URL : https://hal.archives-ouvertes.fr/hal-01517330
Debled-Rennesson, Curvature estimation in noisy curves, LNCS, vol.4673, p.474481, 2007. ,
DOI : 10.1007/978-3-540-74272-2_59
URL : https://hal.archives-ouvertes.fr/hal-00184127/document
Debled-Rennesson, A discrete geometry approach for dominant point detection, Pattern Recognition, vol.44, issue.3244, 2011. ,
Some informational aspects of visual perception., Psychological Review, vol.61, issue.3, p.183193, 1954. ,
DOI : 10.1037/h0054663
The computation of polygonal approximations for 2D contours based on a concavity tree, Journal of Visual Communication and Image Representation, vol.25, issue.8 ,
DOI : 10.1016/j.jvcir.2014.09.012
Polygonal approximation of digital planar curves through vertex betweenness, Information Sciences, vol.222, issue.795, p.804, 2013. ,
DOI : 10.1016/j.ins.2012.07.062
Fast Polygonal Approximation of Digital Curves Using Relaxed Straightness Properties, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.29, issue.9, p.15901602, 2007. ,
DOI : 10.1109/TPAMI.2007.1082
Fast Guaranteed Polygonal Approximations of Closed Digital Curves, LNCS, vol.3540, p.910919, 2005. ,
DOI : 10.1007/11499145_92
A new algorithm for dominant points detection and polygonization of digital curves, Pattern Recognition, vol.36, issue.10, p.22392251, 2003. ,
DOI : 10.1016/S0031-3203(03)00119-5
Polygonal representation of digital planar curves through dominant point detection???a nonparametric algorithm, Pattern Recognition, vol.37, issue.11, p.21132130, 2004. ,
DOI : 10.1016/j.patcog.2004.03.004
Dominant point detection by reverse polygonization of digital curves, Image and Vision Computing, vol.26, issue.5, p.702715, 2008. ,
DOI : 10.1016/j.imavis.2007.08.006
Optimized polygonal approximation by dominant point deletion, Pattern Recognition, vol.41, issue.1, p.227239, 2008. ,
DOI : 10.1016/j.patcog.2007.05.021
Techniques for assessing polygonal approximations of curves, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.19, issue.659666, 1997. ,
A simple algorithm for detection of signicant vertices for polygonal approximation of chain-coded curves, Pattern Recognition Letters, vol.14, issue.12, p.959964, 1993. ,
On the detection of dominant points on digital curves, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.11, issue.8, 1989. ,
DOI : 10.1109/34.31447
Polygonal approximation using integer particle swarm optimization, Information Sciences, vol.278, p.311326, 2014. ,
DOI : 10.1016/j.ins.2014.03.055
Novel method to obtain the optimal polygonal approximation of digital planar curves based on mixed integer programming, Visual Communication and Image Representation, pp.30-106116, 2015. ,
A novel framework for making dominant point detection methods non-parametric, Image and Vision Computing, vol.30, issue.11, 2012. ,
DOI : 10.1016/j.imavis.2012.06.010
Reduced-search dynamic programming for approximation of polygonal curves, Pattern Recognition Letters, vol.24, issue.14, p.22432254, 2003. ,
DOI : 10.1016/S0167-8655(03)00051-5
Polygonal approximation of closed discrete curves, Pattern Recognition, vol.40, issue.4, p.12821293, 2007. ,
DOI : 10.1016/j.patcog.2006.09.002
Optimum polygonal approximation of digitized curves, Pattern Recognition Letters, vol.15, issue.8, p.743750, 1994. ,
DOI : 10.1016/0167-8655(94)90002-7
A new thresholding approach for automatic generation of polygonal approximations, Visual Communication and Image Representation, vol.35, p.155168, 2016. ,
An iterative procedure for the polygonal approximation of planar curves, Computer, Graphic and Image processing, vol.1, p.224256, 1972. ,
Algorithms for the reduction of the number of points required to represent a digitized line or its caricature, Cartographica: The International Journal for Geographic Information and Geovisualization, vol.10, issue.2, p.112122, 1973. ,
Convexity Rule for Shape Decomposition Based on Discrete Contour Evolution, Computer Vision and Image Understanding, vol.73, issue.3, p.441454, 1999. ,
DOI : 10.1006/cviu.1998.0738
URL : http://www.cis.temple.edu/~latecki/Papers/cviu99.pdf
Dominant point detection: A new proposal, Image Vision Computing, vol.23, issue.13, p.12261236, 2005. ,
Detection of signicant points and polygonal approximation of digitized curves, Pattern Recognition Letters, vol.13, issue.6, p.443452, 1992. ,
Dominant point detection using adaptive bending value, Image and Vision Computing, vol.21, issue.6, p.517525, 2003. ,
DOI : 10.1016/S0262-8856(03)00031-3
Angle Detection on Digital Curves, IEEE Transactions on Computers, vol.22, issue.9, 1973. ,
DOI : 10.1109/TC.1973.5009188
Polygonal approximation of digital planar curves through adaptive optimizations, Pattern Recognition Letters, vol.31, issue.13, 2010. ,
DOI : 10.1016/j.patrec.2010.06.007
Géométrie discrète, calculs en nombre entiers et algorithmique , thèse d'état, 1991. ,
Lachaud, Unsupervised , Fast and Precise Recognition of Digital Arcs in Noisy Images, LNCS, vol.6374, p.5968, 2010. ,
Meaningful Scales Detection: an Unsupervised Noise Detection Algorithm for Digital Contours, Image Processing On Line, vol.4, issue.18, 2014. ,
DOI : 10.5201/ipol.2014.75
URL : https://hal.archives-ouvertes.fr/hal-01112936
Meaningful Scales Detection along Digital Contours for Unsupervised Local Noise Estimation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.34, issue.12, p.23792392, 2012. ,
DOI : 10.1109/TPAMI.2012.38
URL : https://hal.archives-ouvertes.fr/hal-00780689
A unied curvature denition for regular, polygonal, and digital planar curves, International Journal Comput. Vision, vol.80, issue.1, p.104124, 2008. ,
DOI : 10.1007/s11263-008-0131-y
A Near-Linear Time Guaranteed Algorithm for Digital Curve Simplication Under the Fréchet Distance, Image Processing On Line, vol.4, p.116127, 2014. ,
Some methods for classication and analysis of multivariate observations, BSMSP, vol.1, p.281297, 1967. ,
Eect of dierent distance measures on the performance of k-means algorithm: An experimental study in matlab, International Journal of Computer Science and Information Technologies, vol.5, p.25012506, 2014. ,
