The resilience of wdm networks to probabilistic geographical failures, Proceedings of IEEE INFOCOM, 2011. ,
On the entity hardening problem in multilayered interdependent networks, WIDN Workshop (INFOCOM WKSHPS), 2015 IEEE Conference on Computer Communications, pp.648-653, 2015. ,
On Robustness in Multilayer Interdependent Networks, International Conference on Critical Information Infrastructures Security, pp.247-250, 2015. ,
DOI : 10.1007/s11067-005-2627-0
On the impact of coding parameters on storage requirement of region-based fault tolerant distributed file system design, 2014 International Conference on Computing, Networking and Communications (ICNC), pp.78-82, 2014. ,
DOI : 10.1109/ICCNC.2014.6785309
Beyond connectivity - new metrics to evaluate robustness of networks, 2011 IEEE 12th International Conference on High Performance Switching and Routing, pp.171-177, 2011. ,
DOI : 10.1109/HPSR.2011.5986022
Design and Analysis of Networks with Large Components in Presence of Region-Based Faults, 2011 IEEE International Conference on Communications (ICC), pp.1-6, 2011. ,
DOI : 10.1109/icc.2011.5962427
Catastrophic cascade of failures in interdependent networks, Nature, vol.80, issue.7291, pp.1025-1028, 2010. ,
DOI : 10.1103/PhysRevE.66.065102
Interdependent Multi-Layer Networks: Modeling and Survivability Analysis with Applications to Space-Based Networks, PLoS ONE, vol.94, issue.11, p.402, 2013. ,
DOI : 10.1371/journal.pone.0060402.t002
URL : http://doi.org/10.1371/journal.pone.0060402
Modelling communication network challenges for Future Internet resilience, survivability, and disruption tolerance: a simulation-based approach, Telecommunication Systems, vol.46, issue.8, pp.751-766, 2013. ,
DOI : 10.1145/1364654.1364687
Optimised heuristics for a geodiverse routing protocol, 2014 10th International Conference on the Design of Reliable Communication Networks (DRCN), pp.1-9, 2014. ,
DOI : 10.1109/DRCN.2014.6816133
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.644.8887
Root Cause Analysis of Failures in Interdependent Power-Communication Networks, 2014 IEEE Military Communications Conference, pp.910-915, 2014. ,
DOI : 10.1109/MILCOM.2014.156
A Network Planning and Management Tool for mitigating the impact of spatially correlated failures in infrastructure networks, 2016 12th International Conference on the Design of Reliable Communication Networks (DRCN), pp.71-78, 2016. ,
DOI : 10.1109/DRCN.2016.7470837
URL : https://hal.archives-ouvertes.fr/hal-01254982
On the smallest pseudo target set identification problem for targeted attack on interdependent power-communication networks, MILCOM 2015, 2015 IEEE Military Communications Conference, pp.1015-1020, 2015. ,
DOI : 10.1109/MILCOM.2015.7357578
Graph Theory, 2005. ,
Networks formed from interdependent networks, Nature Physics, vol.5, issue.1, pp.40-48, 2011. ,
DOI : 10.1103/PhysRevE.74.011122
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.379.8214
Using network measure to reduce state space enumeration in resilient networks, Design of Reliable Communication Networks (DRCN), 2013 9th International Conference on the, pp.250-257, 2013. ,
Region based fault-tolerant distributed file storage system design under budget constraint, 2014 6th International Workshop on Reliable Networks Design and Modeling (RNDM), pp.61-68, 2014. ,
DOI : 10.1109/RNDM.2014.7014932
Progressive Recovery from Failure in Multi-layered Interdependent Network Using a New Model of Interdependency, Conference on Critical Information Infrastructures Security (CRITIS, 2014. ,
DOI : 10.1007/s00453-004-1110-5
Network Reliability With Geographically Correlated Failures, 2010 Proceedings IEEE INFOCOM, pp.1-9, 2010. ,
DOI : 10.1109/INFCOM.2010.5461984
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.181.1192
Modeling Stochastic Correlated Failures and their Effects on Network Reliability, 2011 Proceedings of 20th International Conference on Computer Communications and Networks (ICCCN), pp.1-6, 2011. ,
DOI : 10.1109/ICCCN.2011.6005789
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.377.2266
Identification of K most vulnerable nodes in multi-layered network using a new model of interdependency, 2014 IEEE Conference on Computer Communications Workshops (INFOCOM WKSHPS), pp.831-836, 2014. ,
DOI : 10.1109/INFCOMW.2014.6849338
Region-based faulttolerant distributed file storage system design in networks, Networks, 2015. ,
DOI : 10.1002/net.21655
Region-based connectivity-a new paradigm for design of faulttolerant networks, High Performance Switching and Routing HPSR 2009. International Conference on, pp.1-7, 2009. ,
Fault-Tolerance in Sensor Networks: A New Evaluation Metric, Proceedings IEEE INFOCOM 2006. 25TH IEEE International Conference on Computer Communications, pp.1-12, 2006. ,
DOI : 10.1109/INFOCOM.2006.270
Evaluation of network resilience, survivability, and disruption tolerance: analysis, topology generation, simulation, and experimentation, Telecommunication Systems, vol.99, issue.21, pp.705-736, 2013. ,
DOI : 10.1073/pnas.172501399
Finding Critical Regions and Region-Disjoint Paths in a Network, IEEE/ACM Transactions on Networking, vol.23, issue.3, pp.908-921, 2015. ,
DOI : 10.1109/TNET.2014.2309253
