Diffusive load-balancing policies for dynamic applications, IEEE Concurrency, vol.7, issue.1, pp.22-31, 1999. ,
DOI : 10.1109/4434.749133
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.58.7979
Efficient, proximity-aware load balancing for DHT-based P2P systems, IEEE Transactions on Parallel and Distributed Systems, vol.16, issue.4, pp.349-361, 2005. ,
DOI : 10.1109/TPDS.2005.46
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.129.3053
Parallel and distributed computation: Numerical Methods, 1999. ,
Distributed, secure load balancing with skew, heterogeneity, and churn, Proceedings IEEE 24th Annual Joint Conference of the IEEE Computer and Communications Societies., pp.1419-1430, 2005. ,
DOI : 10.1109/INFCOM.2005.1498366
URL : http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.59.764&rep=rep1&type=pdf
Locality-Aware and Churn-Resilient Load-Balancing Algorithms in Structured Peer-to-Peer Networks, IEEE Transactions on Parallel and Distributed Systems, vol.18, issue.6, pp.849-862, 2007. ,
DOI : 10.1109/TPDS.2007.1040
URL : http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.298.600&rep=rep1&type=pdf
A partially asynchronous and iterative algorithm for distributed load balancing, Parallel Computing, vol.20, issue.6, pp.853-868, 1994. ,
DOI : 10.1016/0167-8191(94)90120-1
A Diffusive Load Balancing Scheme for Clustered Peer-to-Peer Systems, 2009 15th International Conference on Parallel and Distributed Systems, pp.842-847, 2009. ,
DOI : 10.1109/ICPADS.2009.119
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.174.9042
Load balancing in dynamic structured peer-to-peer systems, Performance Evaluation, vol.63, issue.3, pp.3-217, 2006. ,
DOI : 10.1016/j.peva.2005.01.003
An asynchronous and iterative load balancing algorithm for discrete load model, Journal of Parallel and Distributed Computing, vol.62, issue.12, pp.12-1729, 2002. ,
DOI : 10.1016/S0743-7315(02)00006-0
Simple efficient load balancing algorithms for peerto-peer systems, Proceedings of the sixteenth annual ACM symposium on Parallelism in algorithms and architectures, pp.36-43, 2004. ,
Dynamic load balancing for distributed memory multiprocessors, Journal of Parallel and Distributed Computing, vol.7, issue.2, pp.279-301, 1989. ,
DOI : 10.1016/0743-7315(89)90021-X
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.307.2377
eQuus: A Provably Robust and Locality-Aware Peer-to-Peer System, Sixth IEEE International Conference on Peer-to-Peer Computing (P2P'06), pp.3-11, 2006. ,
DOI : 10.1109/P2P.2006.17
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.395.6826
Histogram-Based Global Load Balancing in Structured Peer-to-Peer Systems, Knowledge and Data Engineering IEEE Transactions on, vol.21, issue.4, pp.595-608, 2009. ,
DPTree: A Balanced Tree Based Indexing Framework for Peer-to-Peer Systems, Proceedings of the 2006 IEEE International Conference on Network Protocols, pp.12-21, 2006. ,
DOI : 10.1109/ICNP.2006.320194
The Convergence of Realistic Distributed Load-Balancing Algorithms, Theory of Computing Systems, pp.609-618, 2007. ,
DOI : 10.1007/s00224-006-1214-1
