New interface
Conference papers
Estimating Bandwidth Requirements Using Flow-Level Measurements
Abstract : Bandwidth provisioning is used to dimension links so that a desired performance is met within a network (e.g. QoS metrics). Practical approaches for the estimation of bandwidth needs rely on rough traffic measurements overlooking traffic fluctuations that may have a negative impact on the network performance. On the other hand, effective theoretical solutions for estimating bandwidth needs require traffic measurements at very small timescales, which limit their applicability due to, for example, transmission rates. This paper describes our research goal of proposing a reliable and scalable solution for estimating bandwidth requirements by means of flow-level traffic measurements, as well as our proposed approach to achieve it. This research, currently in its initial phase, is planned to result in a Ph.D. thesis at the end of four years.
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-01585862
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, September 12, 2017 - 10:19:28 AM
Last modification on : Tuesday, September 12, 2017 - 10:22:13 AM
Long-term archiving on: : Wednesday, December 13, 2017 - 3:51:08 PM
File
978-3-642-21484-4_20_Chapter.p...
Identifiers
Citation
Ricardo De O. Schmidt, Aiko Pras. Estimating Bandwidth Requirements Using Flow-Level Measurements. 5th Autonomous Infrastructure, Management and Security (AIMS), Jun 2011, Nancy, France. pp.169-172, ⟨10.1007/978-3-642-21484-4_20⟩. ⟨hal-01585862⟩
Share
Metrics
Record views
16
Files downloads
142
