Abstract : Graph-based semi-supervised learning for classifica- tion endorses a nice interpretation in terms of diffusive random walks, where the regularisation factor in the original optimisation formulation plays the role of a restarting probability. Recently, a new type of biased random walks for characterising certain dynamics on networks have been defined and rely on the γ- th power of the standard Laplacian matrix Lγ, with γ > 0. In particular, these processes embed long range transitions, the Le ́vy flights, that are capable of one-step jumps between far- distant states (nodes) of the graph. The present contribution envisions to build upon these volatile random walks to propose a new version of graph based semi-supervised learning algorithms whose classification outcome could benefit from the dynamics induced by the fractional transition matrix
https://hal.inria.fr/hal-01586767
Contributor : Paulo Gonçalves <>
Submitted on : Wednesday, September 13, 2017 - 11:32:17 AM Last modification on : Monday, January 18, 2021 - 9:32:10 AM
Sarah de Nigris, Esteban Bautista, Patrice Abry, Konstantin Avrachenkov, Paulo Gonçalves. Fractional Graph-based Semi-Supervised Learning. EUSIPCO 2017 - 25th European Signal Processing Conference, Aug 2017, Kos Island, Greece. ⟨hal-01586767⟩
