A priori and a posteriori analysis of finite volume discretizations of Darcy?s equations, Numerische Mathematik, vol.96, issue.1, pp.17-42, 2003. ,
DOI : 10.1007/s00211-002-0436-7
A Posteriori Error Estimation for Lowest Order Raviart???Thomas Mixed Finite Elements, SIAM Journal on Scientific Computing, vol.30, issue.1, pp.189-204, 2007. ,
DOI : 10.1137/06067331X
A posteriori stopping criteria for optimized Schwarz domain decomposition algorithms in mixed formulations, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01529532
Space-time domain decomposition methods and a posteriori error estimates for the heat equation, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01702428
On the implementation of mixed methods as nonconforming methods for second-order elliptic problems, Math. Comp, vol.64, issue.211, pp.943-972, 1995. ,
A stopping criterion for the conjugate gradient algorithm in a finite element method framework, Numerische Mathematik, vol.97, issue.1, pp.1-24, 2004. ,
DOI : 10.1007/s00211-003-0500-y
Stopping criteria for mixed finite element problems, Electron. Trans. Numer. Anal, vol.29, pp.178-19208, 2007. ,
Mixed and nonconforming finite element methods : implementation, postprocessing and error estimates, ESAIM: Mathematical Modelling and Numerical Analysis, vol.19, issue.1, pp.7-32, 1985. ,
DOI : 10.1007/BF01396493
URL : http://www.esaim-m2an.org/articles/m2an/pdf/1985/01/m2an1985190100071.pdf
Adapative Fehlerkontrolle f??r Finite-Elemente-Mehrgitter-Methoden, Computing, vol.54, issue.4, pp.271-288, 1995. ,
DOI : 10.1007/978-3-662-02427-0
A homographic best approximation problem with application to optimized Schwarz waveform relaxation, Mathematics of Computation, vol.78, issue.265, pp.78185-223, 2009. ,
DOI : 10.1090/S0025-5718-08-02145-5
URL : https://hal.archives-ouvertes.fr/hal-00111643
Space???Time Domain Decomposition with Finite Volumes for Porous Media Applications, Domain decomposition methods in science and engineering XXI, pp.483-490, 2014. ,
DOI : 10.1007/978-3-319-05789-7_54
Toward an optimized global-in-time Schwarz algorithm for diffusion equations with discontinuous and spatially variable coefficients. Part 1: the constant coefficients case, pp.170-186, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00661978
Optimized Schwarz Waveform Relaxation Algorithms with Nonconforming Time Discretization for Coupling Convection-diffusion Problems with Discontinuous Coefficients, Domain decomposition methods in science and engineering XVI ,
DOI : 10.1007/978-3-540-34469-8_31
URL : https://hal.archives-ouvertes.fr/inria-00187555
Continuous interior penalty $hp$-finite element methods for advection and advection-diffusion equations, Mathematics of Computation, vol.76, issue.259, pp.1119-1140, 2007. ,
DOI : 10.1090/S0025-5718-07-01951-5
An a posteriori error estimate for vertex-centered finite volume discretizations of immiscible incompressible two-phase flow, Mathematics of Computation, vol.83, issue.285, pp.153-188, 2014. ,
DOI : 10.1090/S0025-5718-2013-02723-8
Domain decomposition methods for the diffusion equation with low-regularity solution, Computers & Mathematics with Applications, vol.74, issue.10, 2017. ,
DOI : 10.1016/j.camwa.2017.07.017
URL : https://hal.archives-ouvertes.fr/hal-01349385
Balancing domain decomposition for mixed finite elements, Mathematics of Computation, vol.64, issue.211, pp.989-1015, 1995. ,
DOI : 10.1090/S0025-5718-1995-1297465-9
An efficient way to assemble finite element matrices in vector languages, BIT Numerical Mathematics, vol.219, issue.13, pp.833-864, 2016. ,
DOI : 10.1007/978-3-642-45367-0
URL : https://hal.archives-ouvertes.fr/hal-00931066
A posteriori error estimates, stopping criteria, and adaptivity for multiphase compositional Darcy flows in porous media, Journal of Computational Physics, vol.276, pp.163-187, 2014. ,
DOI : 10.1016/j.jcp.2014.06.061
URL : https://hal.archives-ouvertes.fr/hal-00839487
An introduction to domain decomposition methods, Algorithms, theory, and parallel implementation, 2015. ,
DOI : 10.1137/1.9781611974065
URL : https://hal.archives-ouvertes.fr/cel-01100932
$hp$-Adaptation Driven by Polynomial-Degree-Robust A Posteriori Error Estimates for Elliptic Problems, SIAM Journal on Scientific Computing, vol.38, issue.5, pp.3220-3246, 2016. ,
DOI : 10.1137/15M1026687
A parallel iterative procedure applicable to the approximate solution of second order partial differential equations by mixed finite element methods, Numerische Mathematik, vol.35, issue.1, pp.95-108, 1993. ,
DOI : 10.1007/BF01385742
Guaranteed, Locally Space-Time Efficient, and Polynomial-Degree Robust a Posteriori Error Estimates for High-Order Discretizations of Parabolic Problems, SIAM Journal on Numerical Analysis, vol.55, issue.6, pp.2811-2834, 2017. ,
DOI : 10.1137/16M1097626
URL : https://hal.archives-ouvertes.fr/hal-01377086
A Posteriori Error Estimation Based on Potential and Flux Reconstruction for the Heat Equation, SIAM Journal on Numerical Analysis, vol.48, issue.1, pp.198-223, 2010. ,
DOI : 10.1137/090759008
URL : https://hal.archives-ouvertes.fr/hal-00383692
Adaptive Inexact Newton Methods with A Posteriori Stopping Criteria for Nonlinear Diffusion PDEs, SIAM Journal on Scientific Computing, vol.35, issue.4, pp.1761-1791, 2013. ,
DOI : 10.1137/120896918
URL : https://hal.archives-ouvertes.fr/hal-00681422
Polynomial-Degree-Robust A Posteriori Estimates in a Unified Setting for Conforming, Nonconforming, Discontinuous Galerkin, and Mixed Discretizations, SIAM Journal on Numerical Analysis, vol.53, issue.2, pp.1058-1081, 2015. ,
DOI : 10.1137/130950100
URL : https://hal.archives-ouvertes.fr/hal-00921583
A method of finite element tearing and interconnecting and its parallel solution algorithm, International Journal for Numerical Methods in Engineering, vol.28, issue.6, pp.1205-1227, 1991. ,
DOI : 10.1016/B978-0-12-068650-6.50029-0
Optimized Schwarz Methods, SIAM Journal on Numerical Analysis, vol.44, issue.2, pp.699-731, 2006. ,
DOI : 10.1137/S0036142903425409
URL : https://hal.archives-ouvertes.fr/hal-00107263
A Schwarz Waveform Relaxation Method for Advection???Diffusion???Reaction Problems with Discontinuous Coefficients and Non-matching Grids, Lect. Notes Comput. Sci. Eng, vol.55, pp.283-290, 2007. ,
DOI : 10.1007/978-3-540-34469-8_33
URL : https://hal.archives-ouvertes.fr/hal-01111940
Optimal Schwarz Waveform Relaxation for the One Dimensional Wave Equation, SIAM Journal on Numerical Analysis, vol.41, issue.5, pp.1643-1681, 2003. ,
DOI : 10.1137/S003614290139559X
Algorithm 932, ACM Transactions on Mathematical Software, vol.40, issue.1, 2013. ,
DOI : 10.1145/2513109.2513115
URL : https://hal.archives-ouvertes.fr/hal-00933643
A New Cement to Glue Nonconforming Grids with Robin Interface Conditions: The Finite Element Case, Domain decomposition methods in science and engineering, pp.259-266, 2005. ,
DOI : 10.1007/3-540-26825-1_24
URL : https://hal.archives-ouvertes.fr/hal-00112937
Time Space Domain Decomposition Methods for Reactive Transport ? Application to CO2 Geological Storage, 2011. ,
URL : https://hal.archives-ouvertes.fr/tel-00634507
Newton-Schwarz Optimised Waveform Relaxation Krylov Accelerators for Nonlinear Reactive Transport, Lect. Notes Comput. Sci. Eng, vol.91, pp.387-394, 2013. ,
DOI : 10.1007/978-3-642-35275-1_45
Discontinuous Galerkin and Nonconforming in Time Optimized Schwarz Waveform Relaxation, In Domain Decomposition Methods in Science and Engineering XIX Lect. Notes Comput. Sci. Eng, vol.78, pp.133-140, 2011. ,
DOI : 10.1007/978-3-642-11304-8_13
Optimized Schwarz Waveform Relaxation and Discontinuous Galerkin Time Stepping for Heterogeneous Problems, SIAM Journal on Numerical Analysis, vol.50, issue.5, pp.2588-2611, 2012. ,
DOI : 10.1137/120865033
URL : https://hal.archives-ouvertes.fr/hal-00479814
Space-Time Domain Decomposition Methods for Diffusion Problems in Mixed Formulations, SIAM Journal on Numerical Analysis, vol.51, issue.6, pp.3532-3559, 2013. ,
DOI : 10.1137/130914401
URL : https://hal.archives-ouvertes.fr/hal-00803796
Space-Time Domain Decomposition for Reduced Fracture Models in Mixed Formulation, SIAM Journal on Numerical Analysis, vol.54, issue.1, pp.288-316, 2016. ,
DOI : 10.1137/15M1009651
Space???time domain decomposition for advection???diffusion problems in mixed formulations, Mathematics and Computers in Simulation, vol.137, pp.366-389, 2017. ,
DOI : 10.1016/j.matcom.2016.11.002
URL : https://hal.archives-ouvertes.fr/hal-01296348
The best interface conditions for domain decomposition methods: absorbing boundary conditions, Absorbing Boundaries and Layers, Domain Decomposition Methods, pp.348-373, 2001. ,
A Posteriori Error Estimates Including Algebraic Error and Stopping Criteria for Iterative Solvers, SIAM Journal on Scientific Computing, vol.32, issue.3, pp.1567-1590, 2010. ,
DOI : 10.1137/08073706X
A Posteriori Error Estimates for a Discontinuous Galerkin Approximation of Second-Order Elliptic Problems, SIAM Journal on Numerical Analysis, vol.41, issue.6, pp.2374-2399, 2003. ,
DOI : 10.1137/S0036142902405217
A posteriori error analysis for locally conservative mixed methods, Mathematics of Computation, vol.76, issue.257, pp.43-66, 2007. ,
DOI : 10.1090/S0025-5718-06-01903-X
Mastering calculations in linear and nonlinear mechanics. Mechanical Engineering Series, 2005. ,
On the Schwarz alternating method III: a variant for nonoverlapping subdomains, Third International Symposium on Domain Decomposition Methods for Partial Differential Equations, pp.202-223, 1989. ,
Balancing domain decomposition, Communications in Numerical Methods in Engineering, vol.13, issue.3, pp.233-241, 1993. ,
DOI : 10.1137/1.9781611971057.ch5
URL : http://ftp.ccs.uky.edu/mgnet/www/mgnet/www/mgnet/papers/Mandel/bdd.ps.gz
An optimized Schwarz waveform relaxation method for the unsteady convection diffusion equation in two dimensions, Applied Numerical Mathematics, vol.52, issue.4, pp.401-428, 2005. ,
DOI : 10.1016/j.apnum.2004.08.022
Goal-oriented error control of the iterative solution of finite element equations, Journal of Numerical Mathematics, vol.4, issue.2, pp.143-172, 2009. ,
DOI : 10.1137/S003614299732334X
Sharp algebraic and total a posteriori error bounds for h and p finite elements via a multilevel approach, 2017. ,
Estimating and localizing the algebraic and total numerical errors using flux reconstructions, Numerische Mathematik, vol.68, 2017. ,
DOI : 10.1090/S0025-5718-99-01125-4
A GENERAL OUTPUT BOUND RESULT: APPLICATION TO DISCRETIZATION AND ITERATION ERROR ESTIMATION AND CONTROL, Mathematical Models and Methods in Applied Sciences, vol.11, issue.04, pp.685-712, 2001. ,
DOI : 10.1016/S0045-7825(98)00244-8
Robust a Posteriori Error Control and Adaptivity for Multiscale, Multinumerics, and Mortar Coupling, SIAM Journal on Numerical Analysis, vol.51, issue.1, pp.526-554, 2013. ,
DOI : 10.1137/110839047
URL : https://hal.archives-ouvertes.fr/hal-00467738
Approximations in elasticity based on the concept of function space, Quarterly of Applied Mathematics, vol.5, issue.3, pp.241-269, 1947. ,
DOI : 10.1090/qam/25902
A posteriori estimates for partial differential equations, of Radon Series on Computational and Applied Mathematics, 2008. ,
DOI : 10.1515/9783110203042
Strict bounding of quantities of interest in computations based on domain decomposition, Computer Methods in Applied Mechanics and Engineering, vol.287, pp.212-228, 2015. ,
DOI : 10.1016/j.cma.2015.01.009
URL : https://hal.archives-ouvertes.fr/hal-01113852
Strict lower bounds with separation of sources of error in non-overlapping domain decomposition methods, International Journal for Numerical Methods in Engineering, vol.155, issue.1-2, pp.1007-1029, 2016. ,
DOI : 10.1016/S0045-7825(97)00146-1
URL : https://hal.archives-ouvertes.fr/hal-01332674
A strict error bound with separated contributions of the discretization and of the iterative solver in non-overlapping domain decomposition methods, Computer Methods in Applied Mechanics and Engineering, vol.270, pp.293-303, 2014. ,
DOI : 10.1016/j.cma.2013.12.001
URL : https://hal.archives-ouvertes.fr/hal-00919435
Galerkin Finite Element Methods for Parabolic Problems, 1997. ,
DOI : 10.1007/978-3-662-03359-3
A posteriori error estimates for finite element discretizations of the heat equation, Calcolo, vol.40, issue.3, pp.195-212, 2003. ,
DOI : 10.1007/s10092-003-0073-2
A Posteriori Error Estimates for Lowest-Order Mixed Finite Element Discretizations of Convection-Diffusion-Reaction Equations, SIAM Journal on Numerical Analysis, vol.45, issue.4, pp.1570-1599, 2007. ,
DOI : 10.1137/060653184
Unified primal formulation-based a priori and a posteriori error analysis of mixed finite element methods, Mathematics of Computation, vol.79, issue.272, pp.2001-2032, 2010. ,
DOI : 10.1090/S0025-5718-2010-02375-0
