New interface
Journal articles
An all-speed relaxation scheme for gases and compressible materials
Abstract : We present a novel relaxation scheme for the simulation of compressible material flows at all speeds. An Eulerian model describing gases, fluids and elastic solids with the same system of conservation laws is adopted. The proposed numerical scheme is based on a fully implicit time discretization, easily implemented thanks to the linearity of the transport operator in the relaxation system. The spatial discretization is obtained by a combination of upwind and centered schemes in order to recover the correct numerical viscosity in all different Mach regimes. The scheme is validated by simulating gas and liquid flows with different Mach numbers. The simulation of the deformation of compressible solids is also approached, assessing the ability of the scheme in approximating material waves in hyperelastic media.
Document type :
Journal articles
Complete list of metadata
Cited literature [43 references]  Display  Hide  Download
https://hal.inria.fr/hal-01586863
Contributor : Angelo Iollo Connect in order to contact the contributor
Submitted on : Wednesday, September 13, 2017 - 1:23:38 PM
Last modification on : Monday, November 28, 2022 - 6:22:04 PM
Long-term archiving on: : Thursday, December 14, 2017 - 12:47:05 PM
File
article_reviewed.pdf
Identifiers
Collections
Citation
Emanuela Abbate, Angelo Iollo, Gabriella Puppo. An all-speed relaxation scheme for gases and compressible materials. Journal of Computational Physics, 2017, 351, pp.1-24. ⟨10.1016/j.jcp.2017.08.052⟩. ⟨hal-01586863⟩
Share
Metrics
Record views
145
Files downloads
311
