Modelling Social-Aware Forwarding in Opportunistic Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chiara Boldrini
  • Fonction : Auteur
  • PersonId : 1016253
Marco Conti
  • Fonction : Auteur
  • PersonId : 979967
Andrea Passarella
  • Fonction : Auteur
  • PersonId : 979969
Opportunistic networks are one of the most promising evolutions of the traditional Mobile Ad Hoc Networks paradigm. Communications in an opportunistic network rely on the mobility of the users: each message is handed over from node to node, making hop-by-hop decisions to select the node that is better suited for bringing the message closer to its destination. Algorithms exploiting social-awareness are emerging as one of the most efficient categories of forwarding algorithms. However we are currently lacking analytical models able to characterize the performance of social-aware forwarding in opportunistic networks. In this paper we start to fill this gap by proposing an analytical model for the expected number of hops and the expected delay experienced by messages when delivered in an opportunistic social-aware fashion. The model is then used to characterize how the expected delay experienced by messages varies with the different social structures in the network of the users.
978-3-642-25575-5_12_Chapter.pdf (171.04 Ko) Télécharger le fichier
hal-01586891 , version 1 (13-09-2017)
Paternité
Chiara Boldrini, Marco Conti, Andrea Passarella. Modelling Social-Aware Forwarding in Opportunistic Networks. Performance Evaluation of Computer and Communication Systems (PERFORM), Oct 2010, Vienna, Austria. pp.141-152, ⟨10.1007/978-3-642-25575-5_12⟩. ⟨hal-01586891⟩
36 Consultations
75 Téléchargements
