High-order absorbing boundary conditions with edge and corner compatibility for the Helmholtz equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We deal with the finite element solution of 3D time-harmonic acoustic wave problems defined on unbounded domains, but computed using cuboidal computational domains with artificial boundaries. We combine a standard finite element method for the Helmholtz equation with high-order absorbing boundary conditions (on the faces of the domain) and compatibility relations (on the edges and the corners) that provide an arbitrary high accuracy.
Modave2017_ProcAcomen.pdf (1.05 Mo) Télécharger le fichier
hal-01588749 , version 1 (16-09-2017)
  • HAL Id : hal-01588749 , version 1
Axel Modave, Vanessa Mattesi, Christophe Geuzaine. High-order absorbing boundary conditions with edge and corner compatibility for the Helmholtz equation. ACOMEN 2017 - 7th International Conference on Advanced Computational Methods in Engineering, Sep 2017, Ghent, Belgium. ⟨hal-01588749⟩
257 Consultations
98 Téléchargements
