Surrogates and Classification Approaches for Efficient Global Optimization (EGO) with Inequality Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, we compare the use of Gaussian Process (GP) models for the constraints with a classification approach relying on a Least-Squares Support Vector Machine (LS-SVM). We propose several adaptations of the classification approach in order to improve the efficiency of the EGO procedure, in particular an extension of the binary LS-SVM classifier to come-up with a probabilistic estimation of the feasible domain. The efficiencies of the GP models and classification methods are compared in term of computational complexities, distinguishing the construction of the GPmodels or LS-SVM classifier from the resolution of the optimization problem. The effect of the number of design parameters on the numerical costs is also investigated. The approaches are tested on the optimization of a complex non-linear Fluid-Structure Interaction system modeling a two dimensional flexible hydrofoil. Multi-design variables, defining the unloaded geometry of the foil and the characteristics of its elastic trailing edge, are used in the minimization of the foil’s drag, under constraints set to ensure minimal lift force and prevent cavitation at selected boat-speeds.
Fichier non déposé
hal-01589262 , version 1 (18-09-2017)
  • HAL Id : hal-01589262 , version 1
Matthieu Sacher, Régis Duvigneau, Olivier Le Maitre, Matthieu Durand, Elisa Berrini, et al.. Surrogates and Classification Approaches for Efficient Global Optimization (EGO) with Inequality Constraints. SIAM Optimization, May 2017, Vancouver, Canada. ⟨hal-01589262⟩
555 Consultations
0 Téléchargements
