Isogeometric analysis for compressible flows using a Discontinuous Galerkin method - Archive ouverte HAL Access content directly
Preprints, Working Papers, ... Year :
The objective of this work is to investigate a Discontinuous Galerkin (DG) method for compressible Euler equations, based on an isogeometric formulation: the partial differential equations governing the flow are solved on rational parametric elements, that preserve exactly the geometry of boundaries defined by Non-Uniform Rational B-Splines (NURBS), while the same rational approximation space is adopted for the solution. We propose a new approach to construct a DG-compliant computational domain based on NURBS boundaries and examine the resulting modifications that occur in the DG method. Some two-dimensional test-cases with analytical solutions are finally considered to assess the accuracy and illustrate the capabilities of the proposed approach. The critical role of boundary curvature is especially investigated.
cmame.pdf (1.26 Mo) Télécharger le fichier
Dates and versions
hal-01589344 , version 1 (18-09-2017)
hal-01589344 , version 2 (16-11-2017)
hal-01589344 , version 3 (01-02-2018)
Identifiers
  • HAL Id : hal-01589344 , version 1
Cite
Régis Duvigneau. Isogeometric analysis for compressible flows using a Discontinuous Galerkin method. 2017. ⟨hal-01589344v1⟩
434 View
617 Download
Share
