Isogeometric analysis for compressible flows using a Discontinuous Galerkin method - Archive ouverte HAL Access content directly
Preprints, Working Papers, ... Year :
The objective of this work is to investigate a Discontinuous Galerkin (DG) method for compressible Euler equations, based on an isogeometric formulation: the partial differential equations governing the flow are solved on rational parametric elements, that preserve exactly the geometry of boundaries defined by Non-Uniform Rational B-Splines (NURBS), while the same rational approximation space is adopted for the solution. We propose a new approach to construct a DG-compliant computational domain based on NURBS boundaries and examine the resulting modifications that occur in the DG method. Some two-dimensional test-cases with analytical solutions are finally considered to assess the accuracy and illustrate the capabilities of the proposed approach. The critical role of boundary curvature is especially investigated.
cmame_corr.pdf (1.26 Mo) Télécharger le fichier
Dates and versions
hal-01589344 , version 1 (18-09-2017)
hal-01589344 , version 2 (16-11-2017)
hal-01589344 , version 3 (01-02-2018)
Identifiers
  • HAL Id : hal-01589344 , version 2
Cite
Régis Duvigneau. Isogeometric analysis for compressible flows using a Discontinuous Galerkin method. 2017. ⟨hal-01589344v2⟩
433 View
616 Download
Share
