Isogeometric analysis : towards integration of CAD and FEA, 2009. ,
DOI : 10.1002/9780470749081
Isogeometric analysis: CAD, finite elements, NURBS, exact geometry and mesh refinement, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.39-41, pp.4135-4195, 2005. ,
DOI : 10.1016/j.cma.2004.10.008
URL : https://hal.archives-ouvertes.fr/hal-01513346
Isogeometric structural shape optimization, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.33-40, pp.33-40, 2008. ,
DOI : 10.1016/j.cma.2008.01.025
Shape Gradient for Isogeometric Structural Design, Journal of Optimization Theory and Applications, vol.200, issue.49???52, p.161 ,
DOI : 10.1016/j.cma.2011.09.004
URL : https://hal.archives-ouvertes.fr/hal-00998594
Studies of refinement and continuity in isogeometric structural analysis, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.41-44, pp.4160-4183, 2007. ,
DOI : 10.1016/j.cma.2007.04.007
Isogeometric variational 405 multiscale modeling of wall-bounded turbulent flows with weakly-enforced boundary conditions on unstretched meshes, Computer Methods in Applied Mechanics and Engineering, issue.199, pp.780-790, 2010. ,
Isogeometric divergence-conforming B-Splines for the steady Navier?Stokes equations, Mathematical Models and Methods in Ap- 410 plied Sciences ,
DOI : 10.21236/ada560496
Isogeometric Analysis of Navier-Stokes Flow Using Locally Refinable B-Splines, SAGA ? Advances in ShApes, Geometry, and Algebra, pp.299-318, 2014. ,
DOI : 10.1007/978-3-319-08635-4_15
A high-order accurate discontinuous finite element, Higher-order surface treatment for discontinuous Galerkin methods with applications to aerodynamics ,
NURBS???enhanced finite element method for Euler equations, International Journal for Numerical Methods in Fluids, vol.46, issue.5, p.420 ,
DOI : 10.1007/978-3-642-59721-3_1
Curved Mesh Generation and Mesh Refinement using Lagrangian Solid Mechanics, 47th AIAA Aerospace Sciences Meeting including The New Horizons Forum and Aerospace Exposition, pp.425-2009, 2009. ,
DOI : 10.1137/0721042
URL : http://raphael.mit.edu/curved.pdf
Construction of tetrahedral meshes of degree two, International Journal for Numerical Methods in Engineering, vol.4, issue.4, pp.1156-1182, 2012. ,
DOI : 10.1002/9780470611166
A method for computing curved meshes via the linear elasticity analogy, application to fluid dynamics problems, International Journal for Numerical Methods in Fluids, vol.230, issue.11, pp.246-266, 2014. ,
DOI : 10.1016/j.jcp.2010.07.035
URL : https://hal.archives-ouvertes.fr/hal-01045103
The generation of valid curvilinear meshes, Notes on Numerical Fluid Mechanics and Multidisciplinary Design, pp.15-39 ,
Isogeometric analysis using T-splines, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.5-8, pp.5-8, 2010. ,
DOI : 10.1016/j.cma.2009.02.036
URL : https://hal.archives-ouvertes.fr/hal-01517950
Parametrization of computational domain in isogeometric analysis: methods and comparison, Computer Methods in Applied Mechanics and Engineering, vol.200, pp.23-24 ,
URL : https://hal.archives-ouvertes.fr/inria-00530758
Analysis-suitable volume parameterization of multi-block computational domain in isogeometric analysis, Computer Aided Design, vol.45, issue.2, p.440 ,
URL : https://hal.archives-ouvertes.fr/hal-00685002
Optimizing domain parameterization in isogeometric analysis based on Powell???Sabin splines, Journal of Computational and Applied Mathematics, vol.289, p.445 ,
DOI : 10.1016/j.cam.2015.03.024
Isogeometric analysis using LR B-splines, Computer Methods in Applied Mechanics and Engineering, vol.269, pp.471-514, 2014. ,
DOI : 10.1016/j.cma.2013.09.014
Swept volume parameterization for isogeometric analysis, 13th IMA International Conference on Mathematics of Surfaces, pp.19-44, 2009. ,
The finite element method in engineering science, Foundations of the blended isogeometric discontinuous Galerkin (BIDG) method, pp.455-658, 1971. ,
460 [25] C. De Boor, A Practical Guide to Splines, Computer Aided Design, vol.16, issue.7, 1978. ,
The Local Discontinuous Galerkin Method for Time-Dependent Convection-Diffusion Systems, SIAM Journal on Numerical Analysis, vol.35, issue.6, pp.2440-2463, 1998. ,
DOI : 10.1137/S0036142997316712
High-Order Methods for Computational Physics, Ch. Discontinuous Galerkin Methods for Convection-Dominated Problems, 1999. ,
On the Choice of Wavespeeds for the HLLC Riemann Solver, SIAM Journal on Scientific Computing, vol.18, issue.6, pp.1553-1570, 1997. ,
DOI : 10.1137/S1064827593260140
Riemann Solvers and Numerical Methods for Fluid Dynamics, p.475 ,
DOI : 10.1007/978-3-662-03915-1
Case c1.2: Transonic ringleb flow, Tech. rep., MIT, 2012. ,
