Isogeometric analysis : towards integration of CAD and FEA, 2009. ,
DOI : 10.1002/9780470749081
Isogeometric analysis: CAD, finite elements, NURBS, exact geometry and mesh refinement, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.39-41, pp.4135-4195, 2005. ,
DOI : 10.1016/j.cma.2004.10.008
URL : https://hal.archives-ouvertes.fr/hal-01513346
Isogeometric structural shape optimization, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.33-40, pp.33-40, 2008. ,
DOI : 10.1016/j.cma.2008.01.025
Shape Gradient for Isogeometric Structural Design, Journal of Optimization Theory and Applications, vol.200, issue.49???52 ,
DOI : 10.1016/j.cma.2011.09.004
URL : https://hal.archives-ouvertes.fr/hal-00998594
Studies of refinement and continuity in isogeometric structural analysis, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.41-44, pp.4160-4183, 2007. ,
DOI : 10.1016/j.cma.2007.04.007
Isogeometric variational multiscale modeling of wall-bounded turbulent flows with weakly enforced boundary conditions on unstretched meshes, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.13-16, pp.780-790, 2010. ,
DOI : 10.1016/j.cma.2008.11.020
Isogeometric divergence-conforming B-Splines for the steady Navier?Stokes equations, Mathematical Models and Methods in Applied Sciences, vol.23, issue.8 ,
DOI : 10.21236/ada560496
Isogeometric Analysis of Navier-Stokes Flow Using Locally Refinable B-Splines, SAGA ? Advances in ShApes, Geometry, and Algebra, pp.299-318, 2014. ,
DOI : 10.1007/978-3-319-08635-4_15
A High-Order Accurate Discontinuous Finite Element Method for the Numerical Solution of the Compressible Navier???Stokes Equations, Journal of Computational Physics, vol.131, issue.2, pp.267-279, 1997. ,
DOI : 10.1006/jcph.1996.5572
Higher-order surface treatment for discontinuous Galerkin methods with applications to aerodynamics, International Journal for Numerical Methods in Fluids, vol.135, issue.2, pp.323-342, 2015. ,
DOI : 10.1006/jcph.1997.5705
NURBS???enhanced finite element method for Euler equations, International Journal for Numerical Methods in Fluids, vol.46, issue.5 ,
DOI : 10.1007/978-3-642-59721-3_1
URL : http://upcommons.upc.edu/bitstream/2117/8159/3/2008-IJNMF-SFH-blanc.pdf
Curved Mesh Generation and Mesh Refinement using Lagrangian Solid Mechanics, 47th AIAA Aerospace Sciences Meeting including The New Horizons Forum and Aerospace Exposition, 2009. ,
DOI : 10.1137/0721042
URL : http://raphael.mit.edu/curved.pdf
Construction of tetrahedral meshes of degree two, International Journal for Numerical Methods in Engineering, vol.4, issue.4, pp.1156-1182, 2012. ,
DOI : 10.1002/9780470611166
A method for computing curved meshes via the linear elasticity analogy, application to fluid dynamics problems, International Journal for Numerical Methods in Fluids, vol.230, issue.11, pp.246-266, 2014. ,
DOI : 10.1016/j.jcp.2010.07.035
URL : https://hal.archives-ouvertes.fr/hal-01045103
The generation of valid curvilinear meshes, Notes on Numerical Fluid Mechanics and Multidisciplinary Design, pp.15-39 ,
Isogeometric analysis using T-splines, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.5-8, pp.5-8, 2010. ,
DOI : 10.1016/j.cma.2009.02.036
URL : https://hal.archives-ouvertes.fr/hal-01517950
Parametrization of computational domain in isogeometric analysis: methods and comparison, Computer Methods in Applied Mechanics and Engineering, vol.200, pp.23-24 ,
URL : https://hal.archives-ouvertes.fr/inria-00530758
Analysis-suitable volume parameterization of multi-block computational domain in isogeometric analysis, Computer Aided Design, vol.45, issue.2 ,
URL : https://hal.archives-ouvertes.fr/hal-00685002
Optimizing domain parameterization in isogeometric analysis based on Powell???Sabin splines, Journal of Computational and Applied Mathematics, vol.289, pp.68-86, 2015. ,
DOI : 10.1016/j.cam.2015.03.024
Isogeometric analysis using LR B-splines, Computer Methods in Applied Mechanics and Engineering, vol.269, pp.471-514, 2014. ,
DOI : 10.1016/j.cma.2013.09.014
URL : https://brage.bibsys.no/xmlui/bitstream/11250/2478060/1/Johannessen2014iau.pdf
Swept Volume Parameterization for Isogeometric Analysis, 13th IMA International Conference on Mathematics of Surfaces, pp.19-44, 2009. ,
DOI : 10.1145/1330511.1330513
URL : http://www.ag.jku.at/pubs/2009ahjpsv.pdf
Isogeometric triangular Bernstein???B??zier discretizations: Automatic mesh generation and geometrically exact finite element analysis, Computer Methods in Applied Mechanics and Engineering, vol.304, issue.304, pp.378-407, 2016. ,
DOI : 10.1016/j.cma.2016.02.012
Isogeometric unstructured tetrahedral and mixedelement bernstein-bézier discretizations, Computer Methods in Applied Mechanics and Engineering, issue.319, pp.83-123, 2017. ,
DOI : 10.1016/j.cma.2017.02.017
Isogeometric analysis on triangulations, Computer-Aided Design, vol.46, issue.46, pp.45-57, 2014. ,
DOI : 10.1016/j.cad.2013.08.017
Continuity and convergence in rational triangular B??zier??spline based isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.297, issue.297, pp.292-324, 2015. ,
DOI : 10.1016/j.cma.2015.09.001
Isogeometric analysis with B??zier tetrahedra, Computer Methods in Applied Mechanics and Engineering, vol.316, issue.316, pp.782-816, 2017. ,
DOI : 10.1016/j.cma.2016.09.045
The finite element method in engineering science, 1971. ,
Foundations of the blended isogeometric discontinuous Galerkin (BIDG) method, Foundations of the blended isogeometric discontinuous Galerkin (BIDG) method, pp.658-681, 2016. ,
DOI : 10.1016/j.cma.2016.02.015
Sub-Cell Shock Capturing for Discontinuous Galerkin Methods, 44th AIAA Aerospace Sciences Meeting and Exhibit, 2006. ,
DOI : 10.1016/0021-9991(81)90128-5
Curves and Surfaces for Computer-Aided Geometric Design, 1989. ,
A Practical Guide to Splines, 1978. ,
The NURBS book, 1995. ,
DOI : 10.1007/978-3-642-97385-7
The Local Discontinuous Galerkin Method for Time-Dependent Convection-Diffusion Systems, SIAM Journal on Numerical Analysis, vol.35, issue.6, pp.2440-2463, 1998. ,
DOI : 10.1137/S0036142997316712
URL : http://historical.ncstrl.org/tr/pdf/icase/TR-97-32.pdf
High-Order Methods for Computational Physics, Ch. Discontinuous Galerkin Methods for Convection-Dominated Problems, 1999. ,
On the Choice of Wavespeeds for the HLLC Riemann Solver, SIAM Journal on Scientific Computing, vol.18, issue.6, pp.1553-1570, 1997. ,
DOI : 10.1137/S1064827593260140
Riemann Solvers and Numerical Methods for Fluid Dynamics, 1997. ,
DOI : 10.1007/978-3-662-03490-3
Case c1.2: Transonic ringleb flow, Tech. rep., MIT, 2012. ,
