High performance imaging using large camera arrays, ACM Transactions on Graphics, vol.24, issue.3, pp.765-776, 2005. ,
DOI : 10.1145/1073204.1073259
Superresolution with the focused plenoptic camera, Computational Imaging IX, pp.78-730, 2011. ,
DOI : 10.1117/12.872666
Lazy decompression of surface light fields for precomputed global illumination, Rendering Techniques 98, pp.281-292, 1998. ,
DOI : 10.1007/978-3-7091-6453-2_26
Data compression for light-field rendering, IEEE Transactions on Circuits and Systems for Video Technology, vol.10, issue.3, pp.338-343, 2000. ,
DOI : 10.1109/76.836278
Light field compression using disparity-compensated lifting and shape adaptation, IEEE Transactions on Image Processing, vol.15, issue.4, pp.793-806, 2006. ,
DOI : 10.1109/TIP.2005.863954
Efficient intra prediction scheme for light field image compression, 2014 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.539-543, 2014. ,
DOI : 10.1109/ICASSP.2014.6853654
Homographybased low rank approximation of light fields for compression, IEEE International Conf. on Acoustics, Speech and Signal Processing, p.2017 ,
Graph-Based Representation for Multiview Image Geometry, IEEE Transactions on Image Processing, vol.24, issue.5, pp.1573-1586, 2015. ,
DOI : 10.1109/TIP.2015.2400817
URL : https://hal.archives-ouvertes.fr/hal-01116211
Rate-Distortion Optimized Graph-Based Representation for Multiview Images With Complex Camera Configurations, Overview of the high efficiency video coding (HEVC) standard , " Circuits and Systems for Video Technology, pp.1649-1668, 2012. ,
DOI : 10.1109/TIP.2017.2685340
URL : https://hal.archives-ouvertes.fr/hal-01492850
The emerging field of signal processing on graphs: Extending high-dimensional data analysis to networks and other irregular domains, IEEE Signal Processing Magazine, vol.30, issue.3, pp.83-98, 2013. ,
Bit-rate allocation for multi-view video plus depth The True Vision-Capture, Transmission and Display of 3D Video, 3DTV Conference, pp.1-4, 2011. ,
Datasets and Benchmarks for Densely Sampled 4D Light Fields, VMV. Citeseer, pp.225-226, 2013. ,
Depth from combining defocus and correspondence using light-field cameras, Proceedings of the IEEE International Conference on Computer Vision, pp.673-680, 2013. ,
Accurate depth map estimation from a lenslet light field camera, 2015 IEEE Conference on Computer Vision and Pattern Recognition (CVPR), pp.1547-1555, 2015. ,
DOI : 10.1109/CVPR.2015.7298762
Graph-based representation for multiview images with complex camera configurations, 2016 IEEE International Conference on Image Processing (ICIP), pp.1554-1558, 2016. ,
DOI : 10.1109/ICIP.2016.7532619
URL : https://hal.archives-ouvertes.fr/hal-01378422
Using JPEG quantization tables to identify imagery processed by software, Digital Investigation, pp.21-25, 2008. ,
Edge-adaptive transforms for efficient depth map coding, 28th Picture Coding Symposium, pp.566-569, 2010. ,
DOI : 10.1109/PCS.2010.5702565
Graph-based transforms for inter predicted video coding, Image Processing (ICIP), 2015 IEEE International Conference on, pp.3992-3996, 2015. ,
