White Matter Fiber Segmentation Using Functional Varifolds
The extraction of fibers from dMRI data typically produces a large number of fibers, it is common to group fibers into bundles. To this end, many specialized distance measures, such as MCP, have been used for fiber similarity. However, these distance based approaches require point-wise correspondence and focus only on the geometry of the fibers. Recent publications have highlighted that using microstructure measures along fibers improves tractography analysis. Also, many neurodegenerative diseases impacting white matter require the study of microstructure measures as well as the white matter geometry. Motivated by these, we propose to use a novel computational model for fibers, called functional varifolds, characterized by a metric that considers both the geometry and microstructure measure (e.g. GFA) along the fiber pathway. We use it to cluster fibers with a dictionary learning and sparse coding-based framework, and present a preliminary analysis using HCP data.
Domains
Engineering Sciences [physics] Signal and Image processing Computer Science [cs] Computer Vision and Pattern Recognition [cs.CV] Computer Science [cs] Medical Imaging Computer Science [cs] Image Processing [eess.IV] Life Sciences [q-bio] Bioengineering Imaging Life Sciences [q-bio] Neurons and Cognition [q-bio.NC] Neurobiology
