Relay Control Design using Attractive Ellipsoids Method
Based on the attractive ellipsoids method the problem of rejection of both matched and mismatched exogenous disturbances is studied for a linear plants controlled by the generalized relays. Some existing results about local stabiliz-ability as well as matching condition are refined for the system under consideration. The procedure of robust control design for optimal rejection of bounded exogenous disturbances is proposed. The theoretical results are supported with numerical simulations.
