Invariant Ellipsoids Approach to Robust Rejection of Persistent Disturbances, Proceedings of the IFAC World Congress, pp.3976-3981, 2008. ,
DOI : 10.3182/20080706-5-KR-1001.00669
Output linear controller for a class of nonlinear systems using the invariant ellipsoid technique, 2009 American Control Conference, pp.1160-1165, 2009. ,
DOI : 10.1109/ACC.2009.5160434
Robust Control for State Constrained Uncertain Systems: Attractive Ellipsoid Method Approach, 10th IFAC Symposium on Nonlinear Control Systems NOLCOS, 2016. ,
DOI : 10.1016/j.ifacol.2016.10.133
Discontinuous automatic control, 1953. ,
DOI : 10.1515/9781400877218
Relay Control Systems, 1984. ,
Sliding Modes in Control Optimization, 1992. ,
DOI : 10.1007/978-3-642-84379-2
Nonlocal stabilization via delayed relay control rejecting uncertainty in a time delay, International Journal of Robust and Nonlinear Control, vol.14, issue.1, 2004. ,
DOI : 10.1002/rnc.863
Variable Structure Control With Generalized Relays: A Simple Convex Optimization Approach, IEEE Transactions on Automatic Control, vol.60, issue.2, pp.497-502, 2015. ,
DOI : 10.1109/TAC.2014.2331417
URL : https://hal.archives-ouvertes.fr/hal-01006389
Switched affine systems control design with application to DC???DC converters, IET Control Theory & Applications, vol.4, issue.7, pp.1201-1210, 2010. ,
DOI : 10.1049/iet-cta.2009.0246
A bilinear input-output model with state-dependent delay for separated flow control, 2016 European Control Conference (ECC), 2016. ,
DOI : 10.1109/ECC.2016.7810532
URL : https://hal.archives-ouvertes.fr/hal-01298166
Discontinuous control systems : frequency-domain analysis and design, 2009. ,
Sliding Mode Control: Theory and Applications, 1998. ,
The invariance conditions in variable structure systems, Automatica, vol.5, issue.3, pp.287-295, 1969. ,
DOI : 10.1016/0005-1098(69)90071-5
Relay Control Design for Robust Stabilization in a Finite-Time, IEEE Transactions on Automatic Control, vol.62, issue.4, 1109. ,
DOI : 10.1109/TAC.2016.2591725
URL : https://hal.archives-ouvertes.fr/hal-01347196
Local Stabilization of Switched Affine Systems, IEEE Transactions on Automatic Control, vol.60, issue.4, pp.1158-1163, 2015. ,
DOI : 10.1109/TAC.2014.2350211
URL : https://hal.archives-ouvertes.fr/hal-01058070
Sliding mode control on electro-mechanical systems, Mathematical Problems in Engineering, vol.8, issue.4-5, 2009. ,
DOI : 10.1080/10241230306724
Simplex sliding mode control of multi-input systems with chattering reduction and mono-directional actuators, Automatica, vol.47, issue.11, pp.2433-2437, 2011. ,
DOI : 10.1016/j.automatica.2011.08.011
Vector method of design of sliding motion and simplex algorithms, Automation and Remote Control, vol.46, pp.830-837, 1985. ,
Quadratic stabilization of a switched affine system about a nonequilibrium point, Proceeding of the, 2004. ,
Differential Equations with Discontinuous Righthand Sides, 1988. ,
DOI : 10.1007/978-94-015-7793-9
