Segmentation versus integration in visual motion processing, Trends in Neurosciences, vol.16, issue.7, pp.253-268, 1993. ,
DOI : 10.1016/0166-2236(93)90179-P
Local and Global Representations of Velocity: Transparency, Opponency, and Global Direction Perception, Perception, vol.36, issue.8, pp.995-1010, 1997. ,
DOI : 10.1016/0042-6989(95)00287-1
Neural dynamics of motion integration and segmentation within and across apertures, Vision Research, vol.41, issue.19, pp.2521-2553, 2001. ,
DOI : 10.1016/S0042-6989(01)00131-6
STRUCTURE AND FUNCTION OF VISUAL AREA MT, Annual Review of Neuroscience, vol.28, issue.1, pp.157-189, 2005. ,
DOI : 10.1146/annurev.neuro.26.041002.131052
Phenomenal coherence of moving visual patterns, Nature, vol.20, issue.5892, pp.523-525, 1982. ,
DOI : 10.1113/jphysiol.1979.sp012827
The Analysis of Moving Visual Patterns, Exp Brain Res, vol.11, pp.117-152, 1986. ,
DOI : 10.1007/978-3-662-09224-8_7
Neural correlates of perceptual motion coherence, Nature, vol.358, issue.6385, pp.412-414, 1992. ,
DOI : 10.1038/358412a0
Transparent motion perception as detection of unbalanced motion signals. III. Modeling, J Neurosci, vol.14, pp.7381-7392, 1994. ,
Seeing multiple directions of motion ? physiology and psychophysics, Nature Neuroscience, vol.3, issue.3, pp.270-276, 2000. ,
DOI : 10.1038/72985
Distributed and Dynamic Neural Encoding of Multiple Motion Directions of Transparently Moving Stimuli in Cortical Area MT, Journal of Neuroscience, vol.35, issue.49, pp.16180-16198, 2015. ,
DOI : 10.1523/JNEUROSCI.2175-15.2015
Integration and segregation of multiple motion signals by neurons in area MT of primate, Journal of Neurophysiology, vol.111, issue.2, pp.369-378, 2014. ,
DOI : 10.1152/jn.00254.2013
Single-unit analysis of pattern-motion selective properties in the middle temporal visual area (MT), Experimental Brain Research, vol.75, issue.1, pp.53-64, 1989. ,
DOI : 10.1007/BF00248530
A model of neuronal responses in visual area MT, Vision Research, vol.38, issue.5, pp.369-378, 1998. ,
DOI : 10.1016/S0042-6989(97)00183-1
How MT cells analyze the motion of visual patterns, Nature Neuroscience, vol.15, issue.11, pp.1421-1431, 2006. ,
DOI : 10.1016/j.neuron.2005.05.021
Temporal dynamics of a neural solution to the aperture problem in visual area MT of macaque brain, Nature, vol.409, issue.6823, pp.1421-1431, 2001. ,
DOI : 10.1038/35059085
Dynamics of motion signaling by neurons in macaque area MT, Nature Neuroscience, vol.1, issue.2, pp.220-228, 2005. ,
DOI : 10.1002/cne.902480203
Complex cells as cortically amplified simple cells, Nature Neurosci, vol.2, pp.277-282, 1999. ,
A network model of motion processing in area MT of primates, Journal of Computational Neuroscience, vol.4, issue.4, pp.287-308, 1997. ,
DOI : 10.1023/A:1008868232355
Perceived direction of moving two-dimensional patterns, Vision Research, vol.30, issue.2, pp.273-287, 1990. ,
DOI : 10.1016/0042-6989(90)90043-K
Perceived direction of moving two-dimensional patterns depends on duration, contrast and eccentricity, Vision Research, vol.32, issue.1, pp.135-147, 1992. ,
DOI : 10.1016/0042-6989(92)90121-X
Stimulus-dependent variability and noise correlations in cortical MT neurons, Proceedings of the National Academy of Sciences, vol.421, issue.6921, pp.13162-13167, 2013. ,
DOI : 10.1038/nature01285
Motion detection based on recurrent network dynamics, Frontiers in Systems Neuroscience, vol.91, issue.60, pp.1-13, 2014. ,
DOI : 10.1152/jn.00855.2003
Adaptation without Plasticity, Cell Reports, vol.17, issue.1, pp.58-68, 2016. ,
DOI : 10.1016/j.celrep.2016.08.089
Properties of pattern and component direction-selective cells in area MT of the macaque, Journal of Neurophysiology, vol.115, issue.6, pp.2705-2720, 2016. ,
DOI : 10.1152/jn.00639.2014
The neural representation of speed in macaque area MT, J Neurosci, vol.23, pp.5650-5661, 2003. ,
Tuning for Spatiotemporal Frequency and Speed in Directionally Selective Neurons of Macaque Striate Cortex, Journal of Neuroscience, vol.26, issue.11, pp.2941-2950, 2006. ,
DOI : 10.1523/JNEUROSCI.3936-05.2006
Modeling feature selectivity in local cortical circuits In Methods in neuronal modeling: From ions to networks, pp.499-567, 1998. ,
Bifurcation study of a neural field competition model with an application to perceptual switching in motion integration, Journal of Computational Neuroscience, vol.90, issue.4, pp.193-213, 2014. ,
DOI : 10.1007/s00422-004-0472-8
Elements of applied bifurcation theory, 2013. ,
Dynamics of Orientation Selectivity in the Primary Visual Cortex and the Importance of Cortical Inhibition, Neuron, vol.38, issue.5, pp.689-699, 2003. ,
DOI : 10.1016/S0896-6273(03)00332-5
Mutual repulsion between moving visual targets, Science, vol.205, issue.4413, pp.1399-1401, 1979. ,
DOI : 10.1126/science.472756
Noise and adaptation in multistable perception: Noise drives when to switch, adaptation determines percept choice, Journal of Vision, vol.14, issue.3, p.19, 2014. ,
DOI : 10.1167/14.3.19
Theory of orientation tuning in visual cortex., Proceedings of the National Academy of Sciences, vol.92, issue.9, pp.3844-3848, 1995. ,
DOI : 10.1073/pnas.92.9.3844
Spatial integration by MT pattern neurons: A closer look at pattern-to-component effects and the role of speed tuning, Journal of Vision, vol.8, issue.9, pp.1-14, 2008. ,
DOI : 10.1167/8.9.1
Abstract, Visual Neuroscience, vol.48, issue.01, pp.79-97, 1992. ,
DOI : 10.1038/324253a0
A Model of Motion Transparency Processing with Local Center-Surround Interactions and Feedback, Neural Computation, vol.16, issue.11, pp.2868-2914, 2011. ,
DOI : 10.1113/jphysiol.1978.sp012272
Orthogonal motion after-effect illusion predicted by a model of cortical motion processing, Nature, vol.384, issue.6607, pp.358-360, 1996. ,
DOI : 10.1038/384358a0
The organization of global motion and transparency. In Motion Vision ? Computational, neural and ecological constraints, pp.86-112, 2001. ,
Advancement of motion psychophysics: a review, J Vis, vol.11, pp.1-53, 2001. ,
Modelling the dynamics of motion integration with a new luminance-gated diffusion mechanism, Vision Research, vol.50, issue.17, pp.1676-1692, 2010. ,
DOI : 10.1016/j.visres.2010.05.022
URL : https://hal.archives-ouvertes.fr/inria-00360277
Bifurcation analysis applied to a model of motion integration with a multistable stimulus, Journal of Computational Neuroscience, vol.25, issue.1, pp.103-124, 2013. ,
DOI : 10.1068/p251317
URL : https://hal.archives-ouvertes.fr/hal-00646387
Canonical computations of cerebral cortex, Current Opinion in Neurobiology, vol.37, pp.75-84, 2016. ,
DOI : 10.1016/j.conb.2016.01.008
Responses of MT neurons to type II plaid stimuli, Journal of Vision, vol.10, issue.7, p.932, 2010. ,
DOI : 10.1167/10.7.932
Multi-stable perception balances stability and sensitivity, Frontiers in Computational Neuroscience, vol.7, pp.1-18, 2013. ,
DOI : 10.3389/fncom.2013.00017
Noise-Induced Alternations in an Attractor Network Model of Perceptual Bistability, Journal of Neurophysiology, vol.98, issue.3, pp.1125-1139, 2007. ,
DOI : 10.1152/jn.00116.2007
The relative contribution of noise and adaptation to competition during tri-stable motion perception, Journal of Vision, vol.16, issue.15, pp.1-26, 2016. ,
DOI : 10.1167/16.15.6
URL : https://hal.archives-ouvertes.fr/hal-01383118
The initial phase of auditory and visual scene analysis, Philosophical Transactions of the Royal Society B: Biological Sciences, vol.27, issue.1, pp.942-953, 2012. ,
DOI : 10.1007/s10827-008-0125-3
Perceptual Organization of Tone Sequences in the Auditory Cortex of Awake Macaques, Neuron, vol.48, issue.1, pp.139-148, 2005. ,
DOI : 10.1016/j.neuron.2005.08.039
Shift in smooth-pursuit initiation and MT and MST neural activity under different stimulus conditions, J Neurophysiol, vol.82, pp.1710-1727, 1999. ,
Temporal and spatial limits of pattern motion sensitivity in macaque MT neurons, Journal of Neurophysiology, vol.113, pp.1977-1988, 2015. ,
DOI : 10.1152/jn.00597.2014
Dynamics of Macaque MT Cell Responses to Grating Triplets, Journal of Neuroscience, vol.32, issue.24, pp.8242-8253, 2012. ,
DOI : 10.1523/JNEUROSCI.5787-11.2012
Equalizing excitation???inhibition ratios across visual cortical neurons, Nature, vol.84, issue.7511, pp.596-600, 2014. ,
DOI : 10.1152/physrev.00021.2009
Spatiotemporal dynamics of continuum neural fields, Journal of Physics A: Mathematical and Theoretical, vol.45, issue.3, p.33001, 2012. ,
DOI : 10.1088/1751-8113/45/3/033001
Mean-field equations for stochastic firing-rate neural fields with delays: Derivation and noise-induced transitions, Physica D: Nonlinear Phenomena, vol.241, issue.15, pp.1223-1244, 2012. ,
DOI : 10.1016/j.physd.2012.03.010
central brain, Science, vol.16, issue.6340, pp.849-853, 2017. ,
DOI : 10.18637/jss.v031.i10
Adaptation Disrupts Motion Integration in the Primate Dorsal Stream, Neuron, vol.81, issue.3, pp.674-686, 2014. ,
DOI : 10.1016/j.neuron.2013.11.022
