Pan-retinal characterisation of Light Responses from Ganglion Cells in the Developing Mouse Retina
We have investigated the ontogeny of light-driven responses in mouse retinal ganglion cells (RGCs). Using a large-scale, high-density multielectrode array, we recorded from hundreds to thousands of RGCs simultaneously at pan-retinal level, including dorsal and ventral locations. Responses to di erent contrasts not only revealed a complex developmental pro le for ON, OFF and ON-OFF responses, but also unveiled di erences between dorsal and ventral RGC responses. At eye-opening, dorsal RGCs of all types were more responsive to light, perhaps indicating an environmental priority to nest viewing for pre-weaning pups. The developmental pro le of ON and OFF responses exhibited antagonistic behaviour, with the strongest ON responses shortly after eye-opening, followed by an increase in the strength of OFF responses later on. Further, we found that with maturation receptive eld (RF) center sizes decrease, spike-triggered averaged responses to white noise become stronger, and centers become more circular while maintaining di erences between RGC types. We conclude that the maturation of retinal functionality is not spatially homogeneous, likely re ecting ecological requirements that favour earlier maturation of the dorsal retina.
Neurosciences [q-bio.NC]
