Waring-like decompositions of polynomials, 1 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Linear Algebra and its Applications Année : 2017
Let $f$ be a homogeneous form of degree d in n variables. A Waring decomposition of $f$ is a way to express $$f as a sum of $d th$ powers of linear forms. In this paper we consider the decompositions of a form as a sum of expressions, each of which is a fixed monomial evaluated at linear forms.
CCGO17.pdf (288.64 Ko) Télécharger le fichier
hal-01590206 , version 1 (19-09-2017)
Maria Virginia Catalisano, Luca Chiantini, Anthony Vito Geramita, Alessandro Oneto. Waring-like decompositions of polynomials, 1. Linear Algebra and its Applications, 2017, 533, pp.311 - 325. ⟨10.1016/j.laa.2017.07.021⟩. ⟨hal-01590206⟩
101 Consultations
113 Téléchargements
