Advanced High Dynamic Range Imaging: Theory and Practice, 2011. ,
DOI : 10.1201/b11373
High Dynamic Range Imaging -Acquisition, Display, and Image-Based Lighting, 2010. ,
REAL PIXELS, pp.80-83, 1991. ,
DOI : 10.1016/B978-0-08-050754-5.50025-6
OpenEXR, high dynamic-range (HDR) image file format ,
An adaptive Logluv transform for High Dynamic Range video compression, 2010 IEEE International Conference on Image Processing, 2010. ,
DOI : 10.1109/ICIP.2010.5654069
LogLuv Encoding for Full-Gamut, High-Dynamic Range Images, Journal of Graphics Tools, vol.13, issue.6, pp.15-31, 1998. ,
DOI : 10.1145/46165.48045
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.1.8295
Call for Evidence (CfE) for HDR and WCG Video Coding, 2015. ,
SMPTE 2084 -Perceptual Signal Coding for More Efficient Usage of Bit Codes, 2012. ,
A Display Independent High Dynamic Range Television System, White Paper WPH 309. BBC British Broadcasting Corporation, 2015. ,
DOI : 10.5594/jmi.2016.2548838
ARIB STD-B67 -Essential Parameter Values for the Extended Image Dynamic Range Television System for Programme Production, ARIB Standard. Association of Radio Industries and Businesses, 2015. ,
Recent developments from MPEG in HDR video compression, 2016 IEEE International Conference on Image Processing (ICIP), pp.879-883, 2016. ,
DOI : 10.1109/ICIP.2016.7532483
Joint Baseband Signal Quantization and Transform Coding for High Dynamic Range Video, CoRR Computing Research Repository, vol.abs, 1603. ,
High quality HDR video compression using HEVC main 10 profile, 2016 Picture Coding Symposium (PCS), pp.1-5, 2016. ,
DOI : 10.1109/PCS.2016.7906372
Compression Efficiency Improvement over HEVC Main 10 Profile for HDR and WCG Content, 2016 Data Compression Conference (DCC), pp.279-288, 2016. ,
DOI : 10.1109/DCC.2016.99
Overview of SHVC: Scalable Extensions of the High Efficiency Video Coding Standard, IEEE Transactions on Circuits and Systems for Video Technology, pp.20-34, 2016. ,
DOI : 10.1109/TCSVT.2015.2461951
Adaptive reshaper for high dynamic range and wide color gamut video compression, 2016. ,
DOI : 10.1117/12.2236050
Evaluation of Tone Mapping Operators Using a High Dynamic Range Display, ACM Trans. Graph, 2005. ,
Tone mapping of HDR images: A review, 2012 4th International Conference on Intelligent and Advanced Systems (ICIAS2012), 2012. ,
DOI : 10.1109/ICIAS.2012.6306220
Photographic Tone Reproduction for Digital Images, ACM Trans. Graph, 2002. ,
DOI : 10.1145/566654.566575
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.164.483
Display adaptive tone mapping Optimizing a Tone Curve for Backward Compatible High Dynamic Range Image and Video Compression, ACM Trans. Graph. IEEE Trans. on Image Processing, vol.21, 2008. ,
Improved Tone Mapping Operator for HDR Coding Optimizing the Distortion/Spatial Complexity Trade-off, Signal Processing Conference (EUSIPCO) Proc. of the European ,
URL : https://hal.archives-ouvertes.fr/hal-01141081
Rate Distortion Optimized Tone Curve for High Dynamic Range Compression, Signal Processing Conference (EUSIPCO) Proc. of the European, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00998480
Visually-favorable tone-mapping with high compression performance, 2010 IEEE International Conference on Image Processing, pp.1285-1288, 2010. ,
DOI : 10.1109/ICIP.2010.5653283
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.191.219
Visually Favorable Tone-Mapping With High Compression Performance in Bit-Depth Scalable Video Coding, IEEE Transactions on Multimedia, vol.15, issue.7, 2013. ,
DOI : 10.1109/TMM.2013.2266633
Optimized tone mapping with LDR image quality constraint for backward-compatible high dynamic range image and video coding, 2013 IEEE International Conference on Image Processing, 2013. ,
DOI : 10.1109/ICIP.2013.6738363
URL : https://hal.archives-ouvertes.fr/hal-01436223
Methods for improving the tone mapping for backward compatible high dynamic range image and video coding, Signal Processing: Image Communication, vol.29, issue.2, 2014. ,
DOI : 10.1016/j.image.2013.08.017
Rate-distortion optimization of a tone mapping with SDR quality constraint for backward-compatible high dynamic range compression, 2016 IEEE International Conference on Image Processing (ICIP), 2016. ,
DOI : 10.1109/ICIP.2016.7532585
URL : https://hal.archives-ouvertes.fr/hal-01377701
Elements of Information Theory, 2006. ,
DOI : 10.1002/047174882x
Overview of the High Efficiency Video Coding (HEVC) Standard, IEEE Transactions on Circuits and Systems for Video Technology, pp.1649-1668, 2012. ,
DOI : 10.1109/TCSVT.2012.2221191
A Bit Allocation Method Based on Picture Activity for Still Image Coding, IEEE Transactions on Image Processing, vol.8, issue.7, pp.974-977, 1999. ,
Adaptive Intra-frame Rate Control for H.264/AVC, 2009 Third International Conference on Multimedia and Ubiquitous Engineering, pp.54-58, 2009. ,
DOI : 10.1109/MUE.2009.21
A new rate-complexity-QP algorithm (RCQA) for HEVC intra-picture rate control, 2014 International Conference on Computing, Networking and Communications (ICNC), pp.375-380, 2014. ,
DOI : 10.1109/ICCNC.2014.6785363
Computing a Trust Region Step, SIAM Journal on Scientific and Statistical Computing, vol.4, issue.3, pp.553-572, 1983. ,
DOI : 10.1137/0904038
Convex Optimization, 2004. ,
High dynamic range image examples ,
Performance evaluation of objective quality metrics for HDR image compression Available: https, Applications of Digital Image Processing XXXVII. SPIE, 2014. ,
