Code Cache Management in Dynamic Optimization Systems, 2004. ,
Qiang Dou: A Novel Chaining Approach for Direct Control Transfer Instructions, Digital Computing Infrastructure and Applications, in conjunction with the 16th International Conference on Parallel and Distributed Systems, pp.664-669, 2010. ,
The Transmeta Code MorphingTM Software: Using Speculation, Recovery, and Adaptive Retranslation to Address Real-Life Challenges, 1st Annual IEEE/ACM International Symposium on Code Generation and Optimization (CGO'03), pp.15-24, 2003. ,
DAISY: Dynamic Compilation for 100% Architectural Compatibility, 24th International Symposium on Computer Architecture (ISCA'97), pp.26-37, 1997. ,
Zemach: IA- 32 Execution Layer: a two-phase dynamic translator designed to support IA-32 applications on Itanium®-based systems, 36th International Symposium on Microarchitecture (MICRO'03), pp.191-204, 2003. ,
Dynamo: A Transparent Dynamic Optimization System, the ACM SIGPLAN Conference on Programming Language Design and Implementation (PLDI'00), pp.1-12, 2000. ,
Herdeg: Digital FX!32: Combinning Emulation and Binary Translation, In: Digital Techncal Journal, vol.9, issue.1, pp.3-12, 1997. ,
Cifuentes: Machine-Adaptable Dynamic Binary Translation, In: the ACM SIGPLAN Workshop on Dynamic and Adaptive Compilation and Optimization, pp.41-51, 2000. ,
Fisher: DELI: A New Run-Time Control Point, the 35th International Symposium on Microarchitecture, pp.257-268, 2002. ,
A Co-Designed Virtual Machine for Instruction Level Distributed Processing, 2004. ,
Computer Architecture: A Quantitative Approach, 2002. ,
Research on Dynamic Binary Translation Based Co-Designed Virtual Machine, 2010. ,
