Subtropical Satisfiability
Quantifier-free nonlinear arithmetic (QF_NRA) appears in many applications of satisfiability modulo theories solving (SMT). Accordingly , efficient reasoning for corresponding constraints in SMT theory solvers is highly relevant. We propose a new incomplete but efficient and terminating method to identify satisfiable instances. The method is derived from the subtropical method recently introduced in the context of symbolic computation for computing real zeros of single very large multivariate polynomials. Our method takes as input conjunctions of strict polynomial inequalities, which represent more than 40% of the QF_NRA section of the SMT-LIB library of benchmarks. The method takes an abstraction of polynomials as exponent vectors over the natural numbers tagged with the signs of the corresponding coefficients. It then uses, in turn, SMT to solve linear problems over the reals to heuristically find suitable points that translate back to satisfying points for the original problem. Systematic experiments on the SMT-LIB demonstrate that our method is not a sufficiently strong decision procedure by itself but a valuable heuristic to use within a portfolio of techniques.
