Equilibrium fluctuations for the weakly asymmetric discrete Atlas model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
This contribution aims at presenting and generalizing a recent work of Hernández, Jara and Valentim [10]. We consider the weakly asymmetric version of the so-called discrete Atlas model, which has been introduced in [10]. Precisely, we look at some equilibrium fluctuation field of a weakly asymmetric zero-range process which evolves on a discrete half-line, with a source of particles at the origin. We prove that its macroscopic evolution is governed by a stochastic heat equation with Neumann or Robin boundary conditions, depending on the range of the parameters of the model.
Asymmetric-ATLAS-2017-09.pdf (176.79 Ko) Télécharger le fichier
hal-01591186 , version 1 (21-09-2017)
F Hernández, Marielle Simon. Equilibrium fluctuations for the weakly asymmetric discrete Atlas model. 2017. ⟨hal-01591186⟩
90 Consultations
45 Téléchargements
