New interface
Journal articles
Scalable Image Coding based on Epitomes
Martin Alain 1, 2, * Christine Guillemot 1 Dominique Thoreau 2 Philippe Guillotel 2
* Corresponding author
1 Sirocco - Analysis representation, compression and communication of visual data
Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : In this paper, we propose a novel scheme for scalable image coding based on the concept of epitome. An epitome can be seen as a factorized representation of an image. Focusing on spatial scalability, the enhancement layer of the proposed scheme contains only the epitome of the input image. The pixels of the enhancement layer not contained in the epitome are then restored using two approaches inspired from local learning-based super-resolution methods. In the first method, a locally linear embedding model is learned on base layer patches and then applied to the corresponding epitome patches to reconstruct the enhancement layer. The second approach learns linear mappings between pairs of co-located base layer and epitome patches. Experiments have shown that significant improvement of the rate-distortion performances can be achieved compared to an SHVC reference.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01591504
Contributor : Martin Alain Connect in order to contact the contributor
Submitted on : Thursday, September 21, 2017 - 2:45:16 PM
Last modification on : Friday, August 5, 2022 - 2:54:52 PM
File
Epitome_scalable.pdf
Identifiers
Citation
Martin Alain, Christine Guillemot, Dominique Thoreau, Philippe Guillotel. Scalable Image Coding based on Epitomes. IEEE Transactions on Image Processing, 2017, 26 (8), pp.3624-3635. ⟨10.1109/TIP.2017.2702396⟩. ⟨hal-01591504⟩
Share
Metrics
Record views
187
Files downloads
62
