On the Edge-length Ratio of Outerplanar Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We show that any outerplanar graph admits a planar straight-line drawing such that the length ratio of the longest to the shortest edges is strictly less than $2$. This result is tight in the sense that for any $\epsilon > 0$ there are outerplanar graphs that cannot be drawn with an edge-length ratio smaller than $2 - \epsilon$. We also show that every bipartite outerplanar graph has a planar straight-line drawing with edge-length ratio $1$, and that, for any $k \geq 1$, there exists an outerplanar graph with a given combinatorial embedding such that any planar straight-line drawing has edge-length ratio greater than~$k$.
Edge-length-ratio-v4-camera-ready.pdf (321.6 Ko) Télécharger le fichier
hal-01591699 , version 1 (21-09-2017)
  • HAL Id : hal-01591699 , version 1
Sylvain Lazard, William Lenhart, Giuseppe Liotta. On the Edge-length Ratio of Outerplanar Graphs. International Symposium on Graph Drawing and Network Visualization, 2017, Boston, United States. ⟨hal-01591699⟩
119 Consultations
128 Téléchargements
