Youla-Kucera Based Online Closed-Loop Identification For Longitudinal Vehicle Dynamics - Archive ouverte HAL Access content directly
Conference Papers Year :
(1) , (2) , (1)
1
2
Francisco Navas
  • Function : Author
  • PersonId : 1017156
Vicente Milanés
  • Function : Author
  • PersonId : 1024109
This paper deals with the identification of longitudinal dynamics of a cycab for subsequent control performance's improvement. Low-speed vehicle dynamic is used as physical model which non-linear behavior is highly complex to properly identify. Among several identification techniques, closed-loop identification gives better performance in a model-based control design. Here, the Hansen scheme is used to transform a closed-loop identification problem in an open-loop-like. The algorihtm is tested in a string of two cycabs equipped with a proportional-derivative-based cooperative adaptive cruise controller, showing how the resulting model is improved in comparison with an open-loop identification algorithm–ARX model.
YK_based_CL_identification_for_longitudinal_vehicle_dynamics.pdf (884.74 Ko) Télécharger le fichier
Dates and versions
hal-01591705 , version 1 (21-09-2017)
Identifiers
  • HAL Id : hal-01591705 , version 1
Cite
Francisco Navas, Vicente Milanés, Fawzi Nashashibi. Youla-Kucera Based Online Closed-Loop Identification For Longitudinal Vehicle Dynamics. 21st International Conference on System Theory, Control and Computing, Oct 2017, Sinaia, Romania. ⟨hal-01591705⟩
120 View
200 Download
Share
