Experimental study of the robust global synchronization of Brockett oscillators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The European Physical Journal. Special Topics Année : 2017
Hafiz Ahmed
Denis Efimov
This article studies the experimental synchronization of a family of a recently proposed oscillator model, i.e. the Brockett oscillator [Brockett, 2013]. Due to its structural property, Brockett oscillator can be considered as a promising benchmark nonlinear model for investigating synchronization and the consensus phenomena. Our experimental setup consists of analog circuit realizations of a network of Brockett oscillators. Experimental results obtained in this work correspond to the prior theoretical findings.
AUE_EPJST_Final_hal.pdf (2.07 Mo) Télécharger le fichier
hal-01591927 , version 1 (22-09-2017)
Hafiz Ahmed, Rosane Ushirobira, Denis Efimov. Experimental study of the robust global synchronization of Brockett oscillators. The European Physical Journal. Special Topics, 2017, 226, pp.3199-3210. ⟨10.1140/epjst/e2016-60357-6⟩. ⟨hal-01591927⟩
81 Consultations
149 Téléchargements
