New interface
Conference papers
On the Combination of the Bernays–Schönfinkel–Ramsey Fragment with Simple Linear Integer Arithmetic
Matthias Horbach 1 Marco Voigt 1, 2, 3 Christoph Weidenbach 1, 3
3 VERIDIS - Modeling and Verification of Distributed Algorithms and Systems
MPII - Max-Planck-Institut für Informatik, Inria Nancy - Grand Est, LORIA - FM - Department of Formal Methods
Abstract : In general, first-order predicate logic extended with linear integer arithmetic is undecidable. We show that the Bernays-Schönfinkel-Ramsey fragment (∃ * ∀ *-sentences) extended with a restricted form of linear integer arithmetic is decidable via finite ground instantiation. The identified ground instances can be employed to restrict the search space of existing automated reasoning procedures considerably, e.g., when reasoning about quantified properties of array data structures formalized in Bradley, Manna, and Sipma's array property fragment. Typically, decision procedures for the array property fragment are based on an exhaustive instantiation of universally quantified array indices with all the ground index terms that occur in the formula at hand. Our results reveal that one can get along with significantly fewer instances.
Document type :
Conference papers
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-01592160
Contributor : Stephan Merz Connect in order to contact the contributor
Submitted on : Wednesday, September 27, 2017 - 6:54:51 PM
Last modification on : Saturday, June 25, 2022 - 7:42:40 PM
Long-term archiving on: : Thursday, December 28, 2017 - 12:20:02 PM
File
HorbachVoigtWeidenbachCADE.pdf
Identifiers
Collections
Citation
Matthias Horbach, Marco Voigt, Christoph Weidenbach. On the Combination of the Bernays–Schönfinkel–Ramsey Fragment with Simple Linear Integer Arithmetic. CADE 26 - 26th International Conference on Automated Deduction, Aug 2017, Gothenburg, Sweden. pp.77-94, ⟨10.1007/978-3-319-63046-5_6⟩. ⟨hal-01592160⟩
Share
Metrics
Record views
412
Files downloads
160
