The Bernays–Schönfinkel–Ramsey Fragment with Bounded Difference Constraints over the Reals Is Decidable - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
First-order linear real arithmetic enriched with uninterpreted predicate symbols yields an interesting modeling language. However, satisfiability of such formulas is undecidable, even if we restrict the uninterpreted predicate symbols to arity one. In order to find decidable fragments of this language, it is necessary to restrict the expressiveness of the arithmetic part. One possible path is to confine arithmetic expressions to difference constraints of the form x − y R c, where R ranges over the standard relations <, ≤, =, =, ≥, > and x, y are universally quantified. However, it is known that combining difference constraints with uninterpreted predicate symbols yields an undecidable satisfiability problem again. In this paper, it is shown that satisfiability becomes decidable if we in addition bound the ranges of universally quantified variables. As bounded intervals over the reals still comprise infinitely many values, a trivial instantiation procedure is not sufficient to solve the problem.
VoigtFroCoS.pdf (396.7 Ko) Télécharger le fichier
Dates and versions
hal-01592169 , version 1 (27-09-2017)
Identifiers
Cite
Marco Voigt. The Bernays–Schönfinkel–Ramsey Fragment with Bounded Difference Constraints over the Reals Is Decidable. FroCoS 2017 - 11th International Symposium on Frontiers of Combining Systems, Sep 2017, Brasilia, Brazil. pp.244-261, ⟨10.1007/978-3-319-66167-4_14⟩. ⟨hal-01592169⟩
180 View
102 Download
Share
