Foundational (Co)datatypes and (Co)recursion for Higher-Order Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Aymeric Bouzy
  • Fonction : Auteur
Fabian Meier
  • Fonction : Auteur
We describe a line of work that started in 2011 towards enriching Isabelle/HOL's language with coinductive datatypes, which allow infinite values, and with a more expressive notion of inductive datatype than previously supported by any system based on higher-order logic. These (co)datatypes are complemented by definitional principles for (co)recursive functions and reasoning principles for (co)induction. In contrast with other systems offering codatatypes, no additional axioms or logic extensions are necessary with our approach.
BiendarraBlanchetteEtAl-FroCos.pdf (188.24 Ko) Télécharger le fichier
hal-01592196 , version 1 (27-09-2017)
Julian Biendarra, Jasmin Christian Blanchette, Aymeric Bouzy, Martin Desharnais, Mathias Fleury, et al.. Foundational (Co)datatypes and (Co)recursion for Higher-Order Logic. Frontiers of Combining Systems, 11th International Symposium, Sep 2017, Brasilia, Brazil. pp.3-21, ⟨10.1007/978-3-319-66167-4_1⟩. ⟨hal-01592196⟩
541 Consultations
153 Téléchargements
