New interface
Journal articles
A polynomial-time algorithm for Outerplanar Diameter Improvement
Abstract : The Outerplanar Diameter Improvement problem asks, given a graph $G$ and an integer $D$, whether it is possible to add edges to $G$ in a way that the resulting graph is outerplanar and has diameter at most $D$. We provide a dynamic programming algorithm that solves this problem in polynomial time. Outerplanar Diameter Improvement demonstrates several structural analogues to the celebrated and challenging Planar Diameter Improvement problem, where the resulting graph should, instead, be planar. The complexity status of this latter problem is open.
Complete list of metadata
Cited literature [26 references]  Display  Hide  Download
https://hal.inria.fr/hal-01592242
Contributor : Nathann Cohen Connect in order to contact the contributor
Submitted on : Friday, September 22, 2017 - 9:34:52 PM
Last modification on : Thursday, October 6, 2022 - 10:39:50 AM
Long-term archiving on: : Saturday, December 23, 2017 - 2:28:17 PM
File
Outerplanar-JCSS-revised.pdf
Identifiers
Citation
Nathann Cohen, Daniel Gonçalves, Eun Jung Kim, Christophe Paul, Ignasi Sau Valls, et al.. A polynomial-time algorithm for Outerplanar Diameter Improvement. Journal of Computer and System Sciences, 2017, 89, pp.315 - 327. ⟨10.1016/j.jcss.2017.05.016⟩. ⟨hal-01592242⟩
Share
Metrics
Record views
619
Files downloads
151
