Dynamic Advance Reservation for Grid System Using Resource Pools - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Zhiang Wu
  • Fonction : Auteur
  • PersonId : 1017437
Jie Cao
  • Fonction : Auteur
  • PersonId : 1017438
Youquan Wang
  • Fonction : Auteur
  • PersonId : 1017439
Dynamic behavior of resources is a non-negligible feature in grid system, and most research efforts on advance reservation cannot effectively deal with the negative effect resulted from the dynamic feature. In this paper, a new grid system architecture using resource pool is proposed firstly. Theoretical analysis demonstrates that resource pool can well adapt to dynamic behavior of resources. Secondly, Quality of Service (QoS) distance computation method for hybrid variable types is presented. Then, k-set Availability Prediction Admission Control (kAPAC) algorithm is described in detail. Experimental results show that kAPAC can significantly increase success ratio of reservation, resource utilization and stability of grid system.
978-3-642-24403-2_10_Chapter.pdf (299.79 Ko) Télécharger le fichier
hal-01593027 , version 1 (25-09-2017)
Paternité
Zhiang Wu, Jie Cao, Youquan Wang. Dynamic Advance Reservation for Grid System Using Resource Pools. 8th Network and Parallel Computing (NPC), Oct 2011, Changsha,, China. pp.123-134, ⟨10.1007/978-3-642-24403-2_10⟩. ⟨hal-01593027⟩
65 Consultations
78 Téléchargements
