Detailed proof of the Lemma 1 used in the manuscript " Discontinuous model recovery anti-windup solution for image based visual servoing " submitted to Automatica - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2017
supplementary_proof_lemma1.pdf (163.44 Ko) Télécharger le fichier
hal-01593178 , version 1 (25-09-2017)
  • HAL Id : hal-01593178 , version 1
Laurent Burlion, Luca Zaccarian, Henry de Plinval, Sophie Tarbouriech. Detailed proof of the Lemma 1 used in the manuscript " Discontinuous model recovery anti-windup solution for image based visual servoing " submitted to Automatica. [Research Report] Rapport LAAS n° 17378, ONERA; LAAS; University of Trento. 2017. ⟨hal-01593178⟩
337 Consultations
52 Téléchargements
