Exact and high-order discretization schemes for Wishart processes and their affine extensions, The Annals of Applied Probability, vol.23, issue.3, pp.1025-1073, 2013. ,
DOI : 10.1214/12-AAP863
URL : https://hal.archives-ouvertes.fr/hal-00491371
An Ensemble Kalman Filter with a complex marine ecosystem model: hindcasting phytoplankton in the Cretan Sea, Annales Geophysicae, vol.21, issue.1, pp.399-411, 2003. ,
DOI : 10.5194/angeo-21-399-2003
URL : https://hal.archives-ouvertes.fr/hal-00316987
An Ensemble Adjustment Kalman Filter for Data Assimilation, Monthly Weather Review, vol.129, issue.12, pp.2884-2903, 2001. ,
DOI : 10.1175/1520-0493(2001)129<2884:AEAKFF>2.0.CO;2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.5.9952
A Local Least Squares Framework for Ensemble Filtering, Monthly Weather Review, vol.131, issue.4, pp.634-642, 2003. ,
DOI : 10.1175/1520-0493(2003)131<0634:ALLSFF>2.0.CO;2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.10.6543
An inequality for trace ideals, Communications in Mathematical Physics, vol.16, issue.2, pp.143-148, 1980. ,
DOI : 10.1007/BF01212822
A Linear Systems Primer, Birkhäuser, 2007. ,
Positive-definite matrix processes of finite variation, Probability and Mathematical Statistics, pp.3-43, 2007. ,
Del Moral and A. Niclas. An introduction to Wishart matrix moments, 2017. ,
On the stability of Kalman-Bucy diffusion processes. arXiv e-print, 2017. ,
Perturbations and Projections of Kalman-Bucy Semigroups. arXiv e-print, 2017. ,
Asymptotically distribution-free methods for the analysis of covariance structures, British Journal of Mathematical and Statistical Psychology, vol.37, issue.1, pp.62-83, 1984. ,
DOI : 10.1111/j.2044-8317.1984.tb00789.x
Wishart processes, Journal of Theoretical Probability, vol.20, issue.4, pp.725-751, 1991. ,
DOI : 10.1007/BF01259552
Diffusions of perturbed principal component analysis, Journal of Multivariate Analysis, vol.29, issue.1, pp.127-136, 1989. ,
DOI : 10.1016/0047-259X(89)90080-8
URL : http://doi.org/10.1016/0047-259x(89)90080-8
Global theory of the Riccati equation, Journal of Computer and System Sciences, vol.1, issue.4, pp.349-361, 1967. ,
DOI : 10.1016/S0022-0000(67)80025-4
Analysis Scheme in the Ensemble Kalman Filter, Monthly Weather Review, vol.126, issue.6, pp.1719-1724, 1998. ,
DOI : 10.1175/1520-0493(1998)126<1719:ASITEK>2.0.CO;2
Affine processes on positive semidefinite matrices. The Annals of Applied Probability, pp.397-463, 2011. ,
DOI : 10.2139/ssrn.1481151
URL : http://arxiv.org/abs/0910.0137
Mean field simulation for Monte Carlo integration, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00932211
A Taylor expansion of the square root matrix functional. arXiv e-print, 2017. ,
On the stability and the uniform propagation of chaos properties of ensemble Kalman-Bucy filters, to appear in the Annals of Applied Probability, 2016. ,
On the Stability and the Uniform Propagation of Chaos of a Class of Extended Ensemble Kalman?Bucy Filters, SIAM Journal on Control and Optimization, vol.55, issue.1, pp.119-155, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01469198
Stochastic Processes: From Applications to Theory, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01593827
The Ensemble Kalman Filter: theoretical formulation and practical implementation . Ocean Dynamics, pp.343-367, 2003. ,
DOI : 10.1007/s10236-003-0036-9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.5.6990
Using the EnKF for Assisted History Matching of a North Sea Reservoir Model, SPE Reservoir Simulation Symposium, 2007. ,
DOI : 10.2118/106184-MS
The Wishart Autoregressive process of multivariate stochastic volatility, Journal of Econometrics, vol.150, issue.2, pp.167-181, 2009. ,
DOI : 10.1016/j.jeconom.2008.12.016
Moments of Wishart Processes via Ito Calculus. Theory of Probability & Its Applications, pp.609-625, 2007. ,
DOI : 10.4213/tvp22
Kronecker Products and Matrix Calculus with Applications, J. Wiley & Sons, 1981. ,
Functions of Matrices: Theory and Computation, SIAM, 2008. ,
DOI : 10.1137/1.9780898717778
Topics in Matrix Analysis, 1985. ,
DOI : 10.1017/CBO9780511840371
Data Assimilation Using an Ensemble Kalman Filter Technique, Monthly Weather Review, vol.126, issue.3, pp.796-811, 1998. ,
DOI : 10.1175/1520-0493(1998)126<0796:DAUAEK>2.0.CO;2
URL : http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.3.1706&rep=rep1&type=pdf
Indefinite Stochastic Riccati Equations, SIAM Journal on Control and Optimization, vol.42, issue.1, pp.123-137, 2003. ,
DOI : 10.1137/S0363012901391330
Strong and weak divergence in finite time of Euler's method for stochastic differential equations with non-globally Lipschitz continuous coefficients, Proceedings of the Royal Society of London A: Mathematical, Physical and Engineering Sciences, pp.1563-1576, 2011. ,
DOI : 10.1016/j.jmaa.2005.04.052
A two-stage ensemble Kalman filter for smooth data assimilation, Environmental and Ecological Statistics, vol.131, issue.9, pp.101-110, 2008. ,
DOI : 10.1080/01621459.1989.10478794
URL : http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.129.3631&rep=rep1&type=pdf
Atmospheric Modelling, Data Assimilation, and Predictability, 2003. ,
DOI : 10.1017/cbo9780511802270
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.88.5725
Brownian Motion and Stochastic Calculus, 1996. ,
Noncolliding Brownian motions and Harish-Chandra formula, Electronic Communications in Probability, vol.8, issue.0, pp.112-121, 2003. ,
DOI : 10.1214/ECP.v8-1076
URL : http://arxiv.org/abs/math/0306386
Symmetry of matrix-valued stochastic processes and noncolliding diffusion particle systems, Journal of Mathematical Physics, vol.37, issue.8, pp.3058-3085, 2004. ,
DOI : 10.1063/1.531675
The Advanced Theory of Statistics, C. Griffin & Company, 1943. ,
Aspects of Semidefinite Programming, The Netherlands, vol.65, 2002. ,
DOI : 10.1007/b105286
Deterministic Mean-Field Ensemble Kalman Filtering, SIAM Journal on Scientific Computing, vol.38, issue.3, pp.1251-1279, 2016. ,
DOI : 10.1137/140984415
URL : http://arxiv.org/pdf/1409.0628
Large sample asymptotics for the ensemble Kalman filter. Chapter 22 in The Oxford Handbook of Nonlinear Filtering, pp.598-631, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00744737
Assimilation of ice concentration in a coupled iceocean model using the Ensemble Kalman Filter. Ocean Dynamics, pp.368-388, 2003. ,
Filtering Complex Turbulent Systems, 2012. ,
DOI : 10.1017/CBO9781139061308
Robustness and accuracy of finite ensemble Kalman filters in large dimensions, 2016. ,
On the convergence of the ensemble Kalman filter, Applications of Mathematics, vol.56, issue.6, pp.533-541, 2011. ,
DOI : 10.1007/s10492-011-0031-2
On strong solutions for positive definite jumpdiffusions, Stochastic Processes and Their Applications, pp.2072-2086, 2011. ,
DOI : 10.1016/j.spa.2011.05.006
URL : http://doi.org/10.1016/j.spa.2011.05.006
A CLASS OF MARKOV PROCESSES ASSOCIATED WITH NONLINEAR PARABOLIC EQUATIONS, Proceedings of the National Academy of Sciences, pp.1907-1911, 1966. ,
DOI : 10.1073/pnas.56.6.1907
Asymptotic behaviour of some interacting particle systems; McKean-Vlasov and Boltzmann models Probabilistic Models for Nonlinear Partial Differential Equations, part of the Lecture Notes in Mathematics book series (LNM, pp.42-95, 1996. ,
Reservoir Monitoring and Continuous Model Updating Using Ensemble Kalman Filter, Proceedings of the 2003 SPE Annual Technical Conference and Exhibition, 2003. ,
DOI : 10.2118/84372-PA
A local ensemble Kalman filter for atmospheric data assimilation. Tellus A, pp.415-428, 2004. ,
Using the EnKF for history matching and uncertainty quantification of complex reservoir models, Large-Scale Inverse Problems and Quantification of Uncertainty, pp.247-271, 2010. ,
Topics in propagation of chaos Course given at the Ecole d'Eté de Probabilités de Saint-Flour in 1989, part of the Lecture Notes in Mathematics book series (LNM, pp.164-251, 1991. ,
Nonlinear stability and ergodicity of ensemble based Kalman filters, Nonlinearity, vol.29, issue.2, pp.657-691, 2016. ,
DOI : 10.1088/0951-7715/29/2/657
Nonlinear stability of the ensemble Kalman filter with adaptive covariance inflation, Communications in Mathematical Sciences, vol.14, issue.5, pp.1283-1313, 2016. ,
DOI : 10.4310/CMS.2016.v14.n5.a5
The ubiquitous Kronecker product, Journal of Computational and Applied Mathematics, vol.123, issue.1-2, pp.85-100, 2000. ,
DOI : 10.1016/S0377-0427(00)00393-9
