Optimization of Linear Control Systems: Analytical Methods and Computational Algorithms, of Stability and Control: Theory, Methods and Applications. Gordon and Breach, 1998. ,
Computing the Fr??chet Derivative of the Matrix Exponential, with an Application to Condition Number Estimation, SIAM Journal on Matrix Analysis and Applications, vol.30, issue.4, pp.1639-1657, 2009. ,
DOI : 10.1137/080716426
The complex step approximation to the Fr??chet derivative of a matrix function, Numerical Algorithms, vol.250, issue.1, pp.133-148, 2010. ,
DOI : 10.1137/1.9780898718898
Computing the Fr??chet Derivative of the Matrix Logarithm and Estimating the Condition Number, SIAM Journal on Scientific Computing, vol.35, issue.4, 2013. ,
DOI : 10.1137/120885991
An inequality for trace ideals, Commun. Math. Phys, vol.76, pp.143-148, 1980. ,
A square root formulation of the Kalman covariance equations., AIAA Journal, vol.57, issue.6, pp.1165-1166, 1968. ,
DOI : 10.2514/3.4189
Solution of the matrix equation AX + XB = C [F4], Communications of the ACM, vol.15, issue.9, pp.820-826, 1972. ,
DOI : 10.1145/361573.361582
The operator equation <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:msubsup><mml:mrow><mml:mo>???</mml:mo></mml:mrow><mml:mrow><mml:mi>i</mml:mi><mml:mo>=</mml:mo><mml:mn>0</mml:mn></mml:mrow><mml:mrow><mml:mi>n</mml:mi></mml:mrow></mml:msubsup><mml:msup><mml:mrow><mml:mi>A</mml:mi></mml:mrow><mml:mrow><mml:mi>n</mml:mi><mml:mo>-</mml:mo><mml:mi>i</mml:mi></mml:mrow></mml:msup><mml:msup><mml:mrow><mml:mtext><ce:italic>XB</ce:italic></mml:mtext></mml:mrow><mml:mrow><mml:mi>i</mml:mi></mml:mrow></mml:msup><mml:mo>=</mml:mo><mml:mi>Y</mml:mi></mml:math>, Expositiones Mathematicae, vol.27, issue.3, pp.251-255, 2009. ,
DOI : 10.1016/j.exmath.2009.02.001
Maximum likelihood estimation using square root information filters, IEEE Transactions on Automatic Control, vol.35, issue.12, pp.1293-1298, 1990. ,
DOI : 10.1109/9.61004
A perturbation analysis of stochastic matrix Riccati diffusions, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01593830
Finite dimensional linear systems, Society for Industrial and Applied Mathematics, 2015. ,
DOI : 10.1137/1.9781611973884
Evaluating the Fréchet derivative of the matrix p-th root, Electronic Transactions on Numerical Analysis, vol.38, pp.202-217, 2011. ,
Some inequalities for the square root of a positive definite matrix. Linear Algebra and its applications, pp.321-324, 1968. ,
The Riccati Equation, 2012. ,
DOI : 10.1007/978-3-642-58223-3
A Schur method for the square root of a matrix, pp.127-140, 1983. ,
Application of ADI Iterative Methods to the Restoration of Noisy Images, SIAM Journal on Matrix Analysis and Applications, vol.17, issue.1, pp.165-186, 1996. ,
DOI : 10.1137/S0895479894273687
Linear System Theory and Design Third Edition, 1999. ,
Sylvester's matrix theorem, a section of Fundamentals of Geophysical Data Processing. Online version at sepwww, 1976. ,
Cosmology and perturbations in massive gravity, Arxiv, vol.12063617, 2013. ,
A Schur-Parlett Algorithm for Computing Matrix Functions, SIAM Journal on Matrix Analysis and Applications, vol.25, issue.2, pp.464-485, 2003. ,
DOI : 10.1137/S0895479802410815
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.660.7576
Blocked Schur Algorithms for Computing the Matrix Square Root, Applied Parallel and Scientific Computing: 11th International Conference, pp.171-182, 2013. ,
DOI : 10.1007/978-3-642-36803-5_12
Zahariadea A note on symmetric vielbeins in bimetric, massive, perturbative and non perturbative gravities, Arxiv, vol.1208, p.4493, 2013. ,
Square Root SAM: Simultaneous Localization and Mapping via Square Root Information Smoothing, The International Journal of Robotics Research, vol.23, issue.7, p.12, 2006. ,
DOI : 10.1007/978-3-642-97522-6
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.122.7443
. I: Theoretical Aspects, SIAM Journal on Numerical Analysis, vol.25, issue.5, pp.1055-1073, 1988. ,
DOI : 10.1137/0725061
Improving the Efficiency of Matrix Operations in the Numerical Solution of Stiff Ordinary Differential Equations, ACM Transactions on Mathematical Software, vol.4, issue.2, pp.127-136, 1978. ,
DOI : 10.1145/355780.355784
Methods for the solution ofAXD???BXC=E and its application in the numerical solution of implicit ordinary differential equations, BIT, vol.13, issue.1, pp.341-345, 1980. ,
DOI : 10.1007/BF01932775
A Hessenberg-Schur method for the problem AX + XB= C, IEEE Transactions on Automatic Control, vol.24, issue.6, pp.909-913, 1979. ,
DOI : 10.1109/TAC.1979.1102170
Functions of Matrices : Theory and Computation, 2008. ,
DOI : 10.1137/1.9780898717778
Stable iterations for the matrix square root, Numerical Algorithms, vol.15, issue.2, pp.227-242, 1997. ,
DOI : 10.1023/A:1019150005407
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.153.5966
Computing real square roots of a real matrix, Linear Algebra and its Applications, vol.88, issue.89, pp.405-430, 1987. ,
DOI : 10.1016/0024-3795(87)90118-2
A Schur???Pad?? Algorithm for Fractional Powers of a Matrix, SIAM Journal on Matrix Analysis and Applications, vol.32, issue.3, pp.1056-1078, 2011. ,
DOI : 10.1137/10081232X
Global Convergence of Non-Convex Gradient Descent for Computing Matrix Squareroot. Arxiv 1507, p.5854, 2017. ,
Uniqueness of matrix square roots and an application, Linear Algebra and its Applications, vol.323, issue.1-3, pp.1-3, 2001. ,
DOI : 10.1016/S0024-3795(00)00243-3
A New Extension of the Kalman Filtering to Non Linear Systems, SPIE Proceedings Series, pp.182-193, 1997. ,
Discrete square root filtering: A survey of current techniques, IEEE Transactions on Automatic Control, vol.16, issue.6, pp.727-736, 1971. ,
DOI : 10.1109/TAC.1971.1099816
Algebraic Riccati equations, 1995. ,
A Schur method for solving algebraic Riccati equations, IEEE Transactions on Automatic Control, vol.24, issue.6, pp.913-921, 1979. ,
DOI : 10.1109/TAC.1979.1102178
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.325.369
Simultaneous solutions of Sylvester equations and idempotent matrices separating the joint spectrum, Linear Algebra and its Applications, vol.435, issue.9, pp.2097-2109, 2011. ,
DOI : 10.1016/j.laa.2010.09.034
The Matrix Square Root from a New Functional Perspective: Theoretical Results and Computational Issues, SIAM Journal on Matrix Analysis and Applications, vol.26, issue.2, pp.362-376, 2004. ,
DOI : 10.1137/S0895479803426656
Recent results in least square estimation theory, Annals of Economic and Social Measurement, vol.6, issue.3, 1977. ,
On the nth roots of a complex matrix. The electronic, Journal of Linear Algebra, vol.9, pp.32-41, 2002. ,
Evaluation of Matrix Square Root Operations for UKF within a UAV GPS/INS Sensor Fusion Application, International Journal of Navigation and Observation, vol.34, issue.5, p.416828, 2011. ,
DOI : 10.1109/TCST.2006.880203
Linear model reduction and solution of the algebraic Riccati equation by use of the sign function???, International Journal of Control, vol.10, issue.4, pp.677-687, 1980. ,
DOI : 10.1137/0114044
Perturbation bounds for matrix square roots and pythagorean sums, Linear Algebra and its Applications, vol.174, pp.215-227, 1992. ,
DOI : 10.1016/0024-3795(92)90052-C
Algorithms for Linear-Quadratic Optimization, Pure and Applied Mathematics, vol.200, 1996. ,
Sur les racines des matrices unitaires. Comptes Rendus de l, Académie des Sciences, vol.94, pp.396-399, 1882. ,
On the matrix square root via geometric optimization. ArXiv /1507, p.8366, 2015. ,
DOI : 10.13001/1081-3810.3196
URL : http://repository.uwyo.edu/cgi/viewcontent.cgi?filename=0&article=3196&context=ela&type=additional
The square-root unscented Kalman filter for state and parameter-estimation, 2001 IEEE International Conference on Acoustics, Speech, and Signal Processing. Proceedings (Cat. No.01CH37221), 2001. ,
DOI : 10.1109/ICASSP.2001.940586
Trace bounds on the solution of the algebraic matrix Riccati and Lyapunov equation, IEEE Transactions on Automatic Control, vol.31, issue.7, pp.654-656, 1986. ,
DOI : 10.1109/TAC.1986.1104370
Fast Fusion of Multi-Band Images Based on Solving a Sylvester Equation, IEEE Transactions on Image Processing, vol.24, issue.11, pp.4109-4121, 2015. ,
DOI : 10.1109/TIP.2015.2458572
URL : https://hal.archives-ouvertes.fr/hal-01187314
Least squares stationary optimal control and the algebraic Riccati equation, IEEE Transactions on Automatic Control, vol.16, issue.6, pp.621-634, 1971. ,
DOI : 10.1109/TAC.1971.1099831
