The pseudo-marginal approach for efficient Monte Carlo computations, The Annals of Statistics, vol.37, issue.2, pp.697-725, 2009. ,
DOI : 10.1214/07-AOS574
URL : http://arxiv.org/abs/0903.5480
Adaptive Control Processes: A Guided Tour, 2015. ,
DOI : 10.1515/9781400874668
On the stability of sequential Monte Carlo methods in high dimensions, The Annals of Applied Probability, vol.24, issue.4, pp.1396-1445, 2014. ,
DOI : 10.1214/13-AAP951
Multilevel sequential Monte Carlo samplers. arXiv preprint, 2015. ,
DOI : 10.1016/j.spa.2016.08.004
URL : http://arxiv.org/pdf/1503.07259
Sharp failure rates for the bootstrap particle filter in high dimensions, Pushing the Limits of Contemporary Statistics, pp.318-329, 2008. ,
DOI : 10.1214/074921708000000228
Sparse grids. Acta numerica 13, pp.147-269, 2004. ,
A nonasymptotic theorem for unnormalized Feynman???Kac particle models, Annales de l'Institut Henri Poincar??, Probabilit??s et Statistiques, vol.47, issue.3, pp.629-649, 2011. ,
DOI : 10.1214/10-AIHP358
URL : https://hal.archives-ouvertes.fr/hal-00688479
Feynman-Kac Formulae: Genealogical and Interacting Particle Systems with Applications, 2004. ,
Sequential Monte Carlo samplers, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.55, issue.3, pp.411-436, 2006. ,
DOI : 10.1007/978-1-4757-4145-2
Multilevel Monte Carlo Path Simulation, Operations Research, vol.56, issue.3, pp.607-617, 2008. ,
DOI : 10.1287/opre.1070.0496
Multilevel Monte Carlo methods, Acta Numerica, vol.24, pp.259-328, 2015. ,
DOI : 10.1017/S096249291500001X
Multilevel Monte Carlo methods. Large-scale scientific computing, pp.58-67, 2001. ,
Complexity analysis of accelerated MCMC methods for Bayesian inversion, Inverse Problems, vol.29, issue.8, p.85010, 2013. ,
DOI : 10.1088/0266-5611/29/8/085010
Multilevel ensemble Kalman filtering. arXiv preprint, 2015. ,
DOI : 10.1137/15m100955x
URL : http://arxiv.org/pdf/1502.06069
Bayesian model averaging: a tutorial, Statist. Sci, vol.14, pp.382-401, 1999. ,
Multilevel particle filter. arXiv preprint, 2015. ,
A hierarchical multilevel Markov chain Monte Carlo algorithm with applications to uncertainty quantification in subsurface flow. arXiv preprint, 2013. ,
Introduction: Uncertainty Quantification and Propagation, 2010. ,
Stochastic Differential Equations, 2003. ,
Unbiased Estimation with Square Root Convergence for SDE Models, Operations Research, vol.63, issue.5, pp.1026-1043, 2015. ,
DOI : 10.1287/opre.2015.1404
Sparse tensor discretizations of high-dimensional parametric and stochastic PDEs, Acta Numerica, vol.15, p.291, 2011. ,
DOI : 10.1007/978-1-4684-9215-6
Non-asymptotic error bounds for sequential MCMC and stability of Feynman-Kac operators. arXiv preprint, 2012. ,
An introduction to stochastic partial differential equations, 1986. ,
DOI : 10.1007/BFb0074920
Evaluating Uncertainty in Engineering Calculations, Journal of Petroleum Technology, vol.19, issue.12, pp.1-595, 1967. ,
DOI : 10.2118/1928-PA
Bayesian Model Selection and Model Averaging, Journal of Mathematical Psychology, vol.44, issue.1, pp.92-107, 2000. ,
DOI : 10.1006/jmps.1999.1278
Toward Automatic Model Comparison: An Adaptive Sequential Monte Carlo Approach, Journal of Computational and Graphical Statistics, vol.56, issue.3, 2016. ,
DOI : 10.1080/02664763.2013.772569
URL : http://www.tandfonline.com/doi/pdf/10.1080/10618600.2015.1060885?needAccess=true
