Exponential mixing properties for time inhomogeneous diffusion processes with killing
Pierre Del Moral 1, 2 Denis Villemonais 3, 4
1 CQFD - Quality control and dynamic reliability
IMB - Institut de Mathématiques de Bordeaux, Inria Bordeaux - Sud-Ouest
3 TOSCA - TO Simulate and CAlibrate stochastic models
CRISAM - Inria Sophia Antipolis - Méditerranée , IECL - Institut Élie Cartan de Lorraine : UMR7502
4 Probabilités et statistiques
Abstract : We consider an elliptic and time-inhomogeneous diffusion process with time-periodic coefficients evolving in a bounded domain of $\mathbb{R}^d$ with a smooth boundary. The process is killed when it hits the boundary of the domain (hard killing) or after an exponential time (soft killing) associated with some bounded rate function. The branching particle interpretation of the non absorbed diffusion again behaves as a set of interacting particles evolving in an absorbing medium. Between absorption times, the particles evolve independently one from each other according to the diffusion semigroup; when a particle is absorbed, another selected particle splits into two offsprings. This article is concerned with the stability properties of these non absorbed processes. Under some classical ellipticity properties on the diffusion process and some mild regularity properties of the hard obstacle boundaries, we prove an uniform exponential strong mixing property of the process conditioned to not be killed. We also provide uniform estimates w.r.t. the time horizon for the interacting particle interpretation of these non-absorbed processes, yielding what seems to be the first result of this type for this class of diffusion processes evolving in soft and hard obstacles, both in homogeneous and non-homogeneous time settings.
Type de document :
Article dans une revue
Bernoulli, Bernoulli Society for Mathematical Statistics and Probability, 2018, 24 (2), pp.1010-1032
Liste complète des métadonnées
Littérature citée [33 références]  Voir  Masquer  Télécharger
https://hal.archives-ouvertes.fr/hal-01083297
Contributeur : Denis Villemonais <>
Soumis le : samedi 19 mars 2016 - 08:52:33
Dernière modification le : mercredi 10 octobre 2018 - 10:10:36
Document(s) archivé(s) le : lundi 20 juin 2016 - 12:19:41
Fichier
2016_R3_Hal_Arxiv_exponential_...
Fichiers produits par l'(les) auteur(s)
Distributed under a Creative Commons Paternité 4.0 International License
  • HAL Id : hal-01083297, version 3
  • ARXIV : 1412.2627
Citation
Pierre Del Moral, Denis Villemonais. Exponential mixing properties for time inhomogeneous diffusion processes with killing. Bernoulli, Bernoulli Society for Mathematical Statistics and Probability, 2018, 24 (2), pp.1010-1032. 〈hal-01083297v3〉
Métriques
Consultations de la notice
949
Téléchargements de fichiers
105
