Audio watermarking robust against time-scale modification and MP3 compression, Signal Processing, vol.88, issue.10, pp.2372-2387, 2008. ,
DOI : 10.1016/j.sigpro.2008.03.019
Data embedding in audio using time-scale modification, IEEE Transactions on Speech and Audio Processing, vol.13, issue.3, pp.432-440, 2005. ,
DOI : 10.1109/TSA.2005.845816
Data hiding in audio signal using Rational Dither Modulation, IEICE Electronics Express, vol.5, issue.7, pp.217-222, 2008. ,
DOI : 10.1587/elex.5.217
High capacity audio watermarking using FFT amplitude interpolation, IEICE Electronics Express, vol.6, issue.14, pp.1057-1063, 2009. ,
DOI : 10.1587/elex.6.1057
URL : https://www.jstage.jst.go.jp/article/elex/6/14/6_14_1057/_pdf
High Capacity Method for Real-Time Audio Data Hiding Using the FFT Transform, Advances in Information Security and Its Application, pp.91-97, 2009. ,
DOI : 10.1109/TSP.2006.881258
Robust High-Capacity Audio Watermarking Based on FFT Amplitude Modification, IEICE Transactions on Information and Systems, vol.93, issue.1, pp.87-93, 2010. ,
DOI : 10.1587/transinf.E93.D.87
DWT-Based High Capacity Audio Watermarking, IEICE Transactions on Fundamentals of Electronics, Communications and Computer Sciences, vol.93, issue.1, pp.331-335, 2010. ,
DOI : 10.1587/transfun.E93.A.331
Localized audio watermarking technique robust against time-scale modification, IEEE Transactions on Multimedia, vol.8, issue.1, pp.60-69, 2006. ,
DOI : 10.1109/TMM.2005.861291
