Twin Clouds: Secure Cloud Computing with Low Latency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cloud computing promises a cost effective enabling technology to outsource storage and massively parallel computations. However, existing approaches for provably secure outsourcing of data and arbitrary computations are either based on tamper-proof hardware or fully homomorphic encryption. The former approaches are not scaleable, while the latter ones are currently not efficient enough to be used in practice.We propose an architecture and protocols that accumulate slow secure computations over time and provide the possibility to query them in parallel on demand by leveraging the benefits of cloud computing. In our approach, the user communicates with a resource-constrained Trusted Cloud (either a private cloud or built from multiple secure hardware modules) which encrypts algorithms and data to be stored and later on queried in the powerful but untrusted Commodity Cloud. We split our protocols such that the Trusted Cloud performs security-critical precomputations in the setup phase, while the Commodity Cloud computes the time-critical query in parallel under encryption in the query phase.
978-3-642-24712-5_3_Chapter.pdf (603.74 Ko) Télécharger le fichier
hal-01596191 , version 1 (27-09-2017)
Paternité
Sven Bugiel, Stefan Nürnberger, Ahmad-Reza Sadeghi, Thomas Schneider. Twin Clouds: Secure Cloud Computing with Low Latency. 12th Communications and Multimedia Security (CMS), Oct 2011, Ghent, Belgium. pp.32-44, ⟨10.1007/978-3-642-24712-5_3⟩. ⟨hal-01596191⟩
366 Consultations
135 Téléchargements
