Abstract : SIP (Session Initiation Protocol) is becoming the mostly deployed signaling protocol for VoIP (Voice over IP). Security is of utmost importance for its usage due to the open architecture of the Internet. Recently, Yoon et al. proposed a SIP authentication scheme based on elliptic curve cryptography (ECC) that claimed to provide higher security than other schemes. However, as demonstrated in this paper, it is still vulnerable to off-line dictionary and partition attacks.
Bart Decker; Jorn Lapon; Vincent Naessens; Andreas Uhl. 12th Communications and Multimedia Security (CMS), Oct 2011, Ghent, Belgium. Springer, Lecture Notes in Computer Science, LNCS-7025, pp.134-143, 2011, Communications and Multimedia Security. 〈10.1007/978-3-642-24712-5_11〉
https://hal.inria.fr/hal-01596196
Contributeur : Hal Ifip
Soumis le : mercredi 27 septembre 2017 - 13:49:48
Dernière modification le : mercredi 27 septembre 2017 - 13:51:54
Document(s) archivé(s) le : jeudi 28 décembre 2017 - 13:42:27
Fuwen Liu, Hartmut Koenig. Cryptanalysis of a SIP Authentication Scheme. Bart Decker; Jorn Lapon; Vincent Naessens; Andreas Uhl. 12th Communications and Multimedia Security (CMS), Oct 2011, Ghent, Belgium. Springer, Lecture Notes in Computer Science, LNCS-7025, pp.134-143, 2011, Communications and Multimedia Security. 〈10.1007/978-3-642-24712-5_11〉. 〈hal-01596196〉
